Tags And Keywordsadministrators, bbcode, html
Post BBCODE - Enabling Html For Admin & Mods Only
We solve this problem ny limiting only the use of the code alone html to the Admins and the Moderators (These last solo in the sections in which Moderators result).
#-----[ OPEN ]--------------------------------------------------
posting.php
#-----[ FIND ]--------------------------------------------------
// Set toggles for various options
if ( !$board_config['allow_html'] )
    $html_on = 0;
else
    $html_on = ( $submit || $refresh ) ? ( ( !empty($_POST['disable_html']) ) ? 0 : true ) : ( ( $userdata['user_id'] == ANONYMOUS ) ? $board_config['allow_html'] : $userdata['user_allowhtml'] );
#-----[ REPLACE ]--------------------------------------------
// Mod for ALLOW HTML to Admins and Moderators - This Mod esclude HTML code for Users and Anonymous - BEGIN
if ($userdata['user_level'] == ADMIN || ($userdata['user_level'] == MOD) && ( $is_auth['auth_mod'] ))
        $html_on = 0;
    else
else
    else
        $html_on = 0;
// Mod for ALLOW HTML to Admins and Moderators - This Mod exlude HTML code for Users and Anonymous - END
If you look well in the code replaced it's used:
This trains Admins and Moderators to the use of the html. If you want that only the Admins can use the html you must change this line in:
if ($userdata['user_level'] == ADMIN) && ( $is_auth['auth_mod'] ))
Now: You must add the < table > button in Posting Body:
[--OPEN--]
templates/mg_themes/bbcb_mg.tpl
[--FIND--]
                    <a href="javascript:BBChl()" ><img border="0" src="{BBCB_MG_IMG_PATH}highlight{BBCB_MG_IMG_EXT}" name="highlight" onMouseOver="helpline('highlight')" alt="{L_BBCB_MG_HIGHLIGHT}" title="{L_BBCB_MG_HIGHLIGHT}" class="bbimages" /></a>
[-- AFTER ADD --]
                    <a href="javascript:BBCtable()" ><img border="0" src="{BBCB_MG_IMG_PATH}table{BBCB_MG_IMG_EXT}" name="highlight" onMouseOver="helpline('table')" alt="{L_BBCB_MG_TABLE}" title="{L_BBCB_MG_TABLE}" class="bbimages" /></a>
Now it needs to remove from all the users the possibility to be able to choose whether to use or I lead the code html in Profile - Control Panel (It's only a matter not to see the function because, if it were also present and the Users choose "Yes" to use him/it, the Code won't work for the change effected in posting.php.
[--OPEN--]
templates/mg_themes/profile_add_body.ypl
[--FIND--]
    <td class="row1"><span class="gen">{L_ALWAYS_ALLOW_HTML}:</span></td>
    <td class="row2">
        <label><input type="radio" name="allowhtml" value="1" {ALWAYS_ALLOW_HTML_YES} /><span class="gen">&nbsp;{L_YES}</span></label>&nbsp;&nbsp;
        <label><input type="radio" name="allowhtml" value="0" {ALWAYS_ALLOW_HTML_NO} /><span class="gen">&nbsp;{L_NO}</span></label>
    </td>
[-- REPLACE WITH --]
    <td class="row2">
    </td>
Last Chage: Now it needs to remove from the Posting Body the possibility from the consumers to be able to choose whether to use or I lead the code html in a determined Post:
[-- OPEN --]
templates/mg_themes/posting_body.tpl
[--FIND--]
                    <!-- BEGIN switch_html_checkbox -->
                    <label><input type="checkbox" name="disable_html" {S_HTML_CHECKED} />&nbsp;{L_DISABLE_HTML}</label><br />
                    <!-- END switch_html_checkbox -->
These are the changes that may have used for allowing the Admins and the Moderators to use the Code html.
Thanks for the useful Topic Zuker:
obus3000 (11 July), BEN-HUR (28 October), Aerosmith (22 November)
Post Re: Enabling Html For Admin & Mods Only
FYI:  I have installed it and not allow Mods, but got this errow
Parse error: syntax error, unexpected T_BOOLEAN_AND in /home/usavngu8/public_html/posting.php on line 504
xmenfile - View user's profileSend private message
HideSimilar Topics
