Page 1 of 3
Goto page 1, 2, 3  Next
Post BBCode Hide Message With An Image Buttom
This is a simple method to have a bbcode Hide message with an image (with the message that says that you must post a reply to view the hidden message).
This image will be shown to explain that there is a hidden message: Example
Rename this image as hide_yes.gif and upload to: /images/bbcb_mg/images/
And this image will be shown when users are able to see the hidden message: Example
Rename this image as hide_no.gif and upload to: /images/bbcb_mg/images/
Example Images of this hack: When the message is hidden / When the message is not hidden
In /includes/bbcode.php
FIND:
            // generate html
            $html = '<blockquote class="quote"><div class="quote-nouser">' . $lang['xs_bbc_hide_message'] . ':</div><div class="post-text">';
            if(!$show)
                return array(
                    'valid' => true,
                    'html' => $html . $lang['xs_bbc_hide_message_explain'] . '</div></blockquote>',
                    'allow_nested' => false,
            else
                return array(
                    'valid' => true,
                    'start' => $html,
                    'end' => '</div></blockquote>'
            // generate html
            if(!$show)
                return array(
                    'valid' => true,
                    'html' => $html . '<center><img src="images/bbcb_mg/images/hide_yes.gif" border="0"/></center><br />' . $lang['xs_bbc_hide_message_explain'] . '</div></blockquote>',
            else
                return array(
                    'valid' => true,
                    'start' => $$html . '<center><img src="images/bbcb_mg/images/hide_no.gif" border="0"/></center><br />',
With this changes, we have an image with the text of BBcode Hide explain.
But, the BBcode Hide doesn't have a bbcode button on posting.php (on reply).
With this changes, you can add this button.
Example Image of the button: Image of the button pressed
Follow this instructions:
Upload to /images/bbcb_mg/images/gif this images:
hide7aq = (rename this to hide.gif)
hide13lp = (rename this to hide1.gif)
In /languages/lang_xxx/lang_bbcb_mg.php
FIND:
$lang['bbcb_mg_highlight'] = 'Highlight';
AFTER, ADD
$lang['bbcb_mg_hide'] = 'Hide a message';
FIND:
$lang['s_highlight_help'] =
AFTER, ADD
$lang['s_hide_help'] = 'Hide a text, registered users must reply or thanks topic to view the hidden message: [hide]Hidden Message[/hide]';
In /includes/bbcb_mg.php
FIND:
    'L_BBCB_MG_HIGHLIGHT' => $lang['bbcb_mg_highlight'],
AFTER, ADD
    'L_BBCB_MG_HIDE' => $lang['bbcb_mg_hide'],
FIND:
    'L_HIGHLIGHT_HELP' => $lang['s_highlight_help'],
AFTER, ADD
    'L_HIDE_HELP' => $lang['s_hide_help'],
In /languages/lang_xxx/bbcb_mg.js
FIND:
s_smiley_creator = 'Smiley Creator: [smiley=1]Text[/smiley] insert a smiley with text';
AFTER, ADD
s_hide_help = 'Hide a text, registered users must reply or thanks topic to view the hidden message: [hide]Hidden Message[/hide]';
FIND:
var Td = 0;
AFTER ADD:
var Hide = 0;
FIND:
'[highlight=]'
AFTER ADD
'[hide]','[/hide]',
FIND:
function BBCbold()
BEFORE ADD:
function BBChide()
    var txtarea = document.post.message;
    if ((clientVer >= 4) && is_ie && is_win)
        theSelection = document.selection.createRange().text;
        if (theSelection != '')
            document.selection.createRange().text = "[hide]" + theSelection + "[/hide]";
            document.post.message.focus();
            return;
    else if (txtarea.selectionEnd && (txtarea.selectionEnd - txtarea.selectionStart > 0))
        //mozWrap(txtarea, "[hide]", "[/hide]");
        mozInsert(txtarea, "[hide]", "[/hide]");
        return;
    if (Hide == 0)
        ToAdd = "[hide]";
        document.post.hide_img.src = bbcb_mg_img_path + "hide1" + bbcb_mg_img_ext;
        Hide = 1;
    else
        ToAdd = "[/hide]";
        document.post.hide_img.src = bbcb_mg_img_path + "hide" + bbcb_mg_img_ext;
        Hide = 0;
    PostWrite(ToAdd);
In /templates/mg_themes/bbcb_mg.tpl
FIND:
                    <a href="javascript:BBChl()" ><img src="{BBCB_MG_IMG_PATH}highlight{BBCB_MG_IMG_EXT}" name="highlight" onMouseOver="helpline('highlight')" alt="{L_BBCB_MG_HIGHLIGHT}" title="{L_BBCB_MG_HIGHLIGHT}" class="bbimages" /></a>
AFTER ADD:
                    <a href="javascript:BBChide()"><img src="{BBCB_MG_IMG_PATH}hide{BBCB_MG_IMG_EXT}" name="hide_img" onMouseOver="helpline('hide')" alt="{L_BBCB_MG_HIDE}" title="{L_BBCB_MG_HIDE}" class="bbimages" /></a>
Now, with this changes, we have a new button to use the bbcode hide in the posting page
Post Re: BBCode Hide message with an image buttom
thank you zuker for this
Play Games at GamesCampus!
Post Re: BBCode Hide Message With An Image Buttom
Thanks this work perfect
diegomakSend private message
hey thank you for that ..really helps worked!!
but.. the combination between thanks button don't work if i press thanks the post is hidded is their a possibillity/solution for that?!?!
testSend private message
there it's no combination in ip for that at the moment
Puting this on bbcode.php
FIND:
Code: [Download] [Show]
           // generate html
            if(!$show)
                return array(
                    'valid' => true,
            else
                return array(
                    'valid' => true,
                    'start' => $html,
           // generate html
            if(!$show)
                return array(
                    'valid' => true,
            else
                return array(
                    'valid' => true,
                    'start' => $html . '<center><img src="images/bbcb_mg/images/hide_no.gif" border="0"/></center><br />',
I have this error:
Parse error: syntax error, unexpected T_VARIABLE, expecting T_OLD_FUNCTION or T_FUNCTION or T_VAR or '}' in /home/www/downloading.mygamesonline.org/includes/bbcode.php on line 3550
   what can i do?
Zuker if you are spanish answer me in spanish plz.
chusrubi2Send private message
u are making some edit wrogn
attach me your file so i can check it
I have added the file adjunt in .rar. Modify it plz
bbcode.rar
Description: File
Filename: bbcode.rar
Filesize: 21.01 KB
Downloaded: 363 Time(s)
But you are gaving me the clean file
Try to do it and if u can't, attach the modded file
Thanks Zuker!!! I did it.
Thanks men.
leonidfgSend private message
I have a problem. I had one modification. When I push the button not view the message Original (Quoted Hidden Message, which is still hidden.). There aren't message
But, if I write a word, I select the word with the mouse and I push the eye,...:
wordundefined
Im spanish, sorry my bad english ^^
IN SPANISH...
Yo tengo un problema. He hecho una modificación. Cuando yo hago click en el botón no veo el mensaje original (....). No me sale nada, en blanco [Así quería yo ^^].... hasta aquí todo bien.
Pero, si yo escribo una palabara, Yo la selecciono con el ratón y pulso en el botón del ojo, me sale...
palabraundefined
Nosé si me explico. Si primero pongo hide y luego escribo bien
SerginiSend private message
Hi again... in all this HIDE button stuff I have another question.
There's a way to the hide messages may be visible only to the registered users without the need of posting a message? An example may be the Thanks button that allow to see the hide messages.
But I didn't find a post with this Thanks button MOD.
Anyone here know how to do it.
Bye...!
I think it has already been posted somewhere here... try to search...
leonidfg wrote: [View Post]
Bye...!
on bbcode.php & viewtopic.php
replace
            if($userdata['session_logged_in'])
                $sql = "SELECT p.poster_id, p.topic_id
                    FROM " . POSTS_TABLE . " p
                    WHERE p.topic_id = $topic_id
                    AND p.poster_id = " . $userdata['user_id'];
                $resultat = $db->sql_query($sql);
                $show = $db->sql_numrows($resultat) ? true : false;
                if ( ($userdata['user_level'] == ADMIN) || ($userdata['user_level'] == MOD))
                    $show = true;
with
                if ( ($userdata['session_logged_in'] )
                    $show = true;
test it
hello can configure to allow groups that not  post to view the content ?
robin crackerSend private messageVisit poster's website
