Post [SOLVED] Open The Quick Links By Default
How can i do this? all should be open and not close even if u click on them.
cyberSend private message
Post Re: Open The Quick LInks By Default
Try this file
nav_quick_links.zip
Description: nav_quick_links.tpl with menues open
Filename: nav_quick_links.zip
Filesize: 2.13 KB
Downloaded: 207 Time(s)
thanx!...doesnt work...!
they are all closed and dont open even if u click them.
cyber, it's a cookie problem of your browser
clean cache & cookies and check again
It still doesnt work even in RC....tried clearing cache or cookies....even i recently formatted my PC!
isnt there any small code change in the current file to make the links open by default? and not close even if u click them?
try to change
display: none
to
display: yes
nope....still doesnt work...
i think there should be a How-to for this!
EDIT:  IT works perfectly!
Just change all the display: none  to display: yes !!!
thnx!
SOLVED
Post Re: [SOLVED] Open The Quick Links By Default
cyber,
It's not the first time u said "it's not working" and say something like
U SHALL MAKE IT WORK
It was my last support for you. I'm sorry
And there is no need to to edit your post's. I've read enought
Zuker wrote: [View Post]
cyber,
I´m totally with you Zuker.
@ cyber,
This is an open Source community and we all spend here many of our free time, because we like to help each other.
So if you cant give us support, no problem, but then you should take resepct to our work and check always twice that if someone provides here and code our help, its not YOUR fault!!!!
Play Games at GamesCampus!
