Post Can't Get Dynamix Menu To Work
Hi
I'm unable to get the dynamic menu in the CMS to work.  I've tried creating a new menu block + category + link, I've tried creating a new category + link in the existing menu block, and I've tried creating a menu link in the existing 'Main Menu' list.  None of them have appeared even though I've set the permission to 'All'
Does anyone have any suggestions?
tc1967ukSend private message
Post Re: Can't Get Dynamix Menu To Work
i can confirm this... it isn't working for me
I don't know maybe i forget to do something
For dynamic Menu you should add dyn_menu block in your page and then choose the menu id.
MelSend private message
Mel wrote: [View Post]
Thanks Mel
Greets
Hi Mel (and thanks)
Sounds like it works for Zuker.  Can you break this down so a noob like mee can understand how to do it too, please?
You need to use the page cms_menu.php, create a new menu block and when you did it you need to add a block to the page using the dyn_menu_bloch.php in CMS page.
Refer to this guide on how to add blocks to your pages.
http://www.icyphoenix.com/viewtopic.php?t=1502
