Post FAP SUPPORT - FAP Guestion
Hello all!
I have just one guestion.
Artie has helped me already with the code so that only registered users can see full images.
##------------------- [ OPEN ] ------------------------------------------------
album_showpage.php
##----------------- [ FIND ] ----------------------------------------------------
// TEMPLATE ASSIGNEMENT
##--------------- [ BEFORE ADD ] -----------------------------------------------------------
if ((!$userdata['session_logged_in']) && ($full_size_param == '&full=true'))
        redirect(append_sid(album_append_uid(LOGIN_MG . "?redirect=album_showpage.$phpEx&pic_id=$pic_id&full=true")));
## --------- [ SAVE FILE ] ---------------------------------------------
#EoM
Now im using hide links mod (http://www.phpbbhacks.com/download/4543),
and i would like that only registered users with more than 10 post can see full images,
and all other`s can see thumbnails and medium images.
I already done this in my wap upload script,but i just can`t get it to work in FAP.
This is what i done in my wap script and it`s working.
if( $userdata['session_logged_in'] & $userdata['user_posts'] >= 10 )
=======some php  comes here======
elseif ( $userdata['user_posts'] >= 10 )
               header("location:===login location===");
else
               header("location:===location for users that have less than 10 posts===");
Like i said in my wap script is working but in FAP can`t get it to work.
Is there any solution?
Sorry for my english i`m from slovenia
Please help.
SiljoSend private message
Post Re: FAP Guestion
Try this:
Take the code ( from above) that I gave you and...
REPLACE
WITH
if (($userdata['user_posts'] < 10) && ($full_size_param == '&amp;full=true'))
        // YOUR CODE TO REDIRECT USERS OF LESS THAN 10 POST
ArtieSend private message
Not working
How about something like all users ( unregistered & members ) see tumbnails and medium pictures and only members of a specific group can see full pics?
This is the code i`m using in my download center and i tried to usit in FAP,but no luck!
First part.
$userid = $userdata['user_id'];
$sql = "SELECT * FROM " . USER_GROUP_TABLE . " WHERE user_id = '$userid'";
$result = $db->sql_query($sql);
$isauth = 0;
while ($row = $db->sql_fetchrow($result))
if ($row['group_id'] == '//GROUP ID NUMBER//'' || $row['group_id'] == '//GROUP ID NUMBER//')
$isauth = 1;
Second part.
if( $userdata['session_logged_in'] & $isauth == '1')
elseif ( $userdata['session_logged_in'] & $isauth == '0')
               header("//NOT IN GROUP LINK//");
else
               header("//LOGIN LINK//");
any idea?
Can this even be done?
Artie wrote: [View Post]
Try this:
REPLACE
if ((!$userdata['session_logged_in']) && ($full_size_param == '&amp;full=true'))
WITH
This works for me.
I do not understand what does not work for you....
Did you place the code as I originally instructed ?
What code did you put in to redirect your users ?
The code that i put in
         message_die(GENERAL_ERROR, "You do not have permission to access this page");
The code works for registered users,but it doesent work for unregistered users?
Any idea?
Please help
That should work for all.
Maybe check that this '&amp;full=true' is not like this '&full=true'
No it`s correct!
Why this code doesent work right?
First part.
$isauth = 0;
$isauth = 1;
Second part.
else
any idea?
please help
No like i said this is what i put in
Well it should work as expected.
Did you place/replace it as described above ....
IN album_showpage.php
BEFORE
Yes i did
        $picm = false;
        $full_size_param = '&amp;full=true';
if ((isset($_GET['slideshow']) && (intval($_GET['slideshow']) > 0)) || (isset($_POST['slideshow']) && (intval($_POST['slideshow']) > 0)))
    $gen_simple_header = true;
    $show_template = 'album_slideshow_body.tpl';
    $nuffimage_pic = ( $picm == false ) ? 'album_pic.' : 'album_picm.';
I don`t think that this 10 post is a good idea,this will bring spamers and usefull stuff to forum.Is there any way to do a group access?
Anybody?
Bump
It seems you didn't forget your attitude to bump your own topics even more than once.
I think I'm giving you a yellow card...
Thanks for the yellow card
I dont like bumping posts,but if i don`t get an answer i have to bump it.
It`s sad that i can`t get a simple answer on my question.If it can`t be done just say so....don`t ignore me
This forum is locked: you cannot post, reply or edit topics.  This topic is locked: you cannot edit posts or make replies.  Page 1 of 2
