Introduction
With the CMS system you can add each kind of block in every page of your Icy Phoenix board. If, for example, you have a particular block that you must put in a lot of personal page (like a footer or sponsor), is very useful to create a custom block in a block file, because you can edit .tpl file only one time and upload it: all your pages will then get the changes!
Instructions
- Create yoursite/blocks/blocks_imp_YOURBLOCK.php
- <?php
- * blocks_imp_YOURBLOCK.php
- * begin : 2007/02/06
- * copyright : Mighty Gorgon
- * website : http://www.mightygorgon.com
- * email : mightygorgon@mightygorgon.com
- * This program is free software; you can redistribute it and/or modify
- * it under the terms of the GNU General Public License as published by
- * the Free Software Foundation; either version 2 of the License, or
- * (at your option) any later version.
- if ( !defined('IN_PHPBB') )
- die('Hacking attempt');
- if(!function_exists(imp_YOURBLOCK_func))
- function imp_YOURBLOCK_func()
- global $lang, $template, $board_config;
- $template->assign_vars(array(
- imp_YOURBLOCK_func();
- Create yoursite/templates/xxx/blocks/YOURBLOCK_block.tpl and put in it your personal HTML code.
- P.S.: replace YOURBLOCK with your personal name! That's all, good work!
Trieste
U.S.A.
