Post CUSTOMIZATION - How To Create A Login Box
We will create a login box at forum index
Will be like this
  loginbox
OPEN
templates/mg_themes/index_body.tpl
{BOARD_INDEX}
BEFORE, ADD
<!-- BEGIN switch_user_logged_out -->
<form method="post" action="{S_LOGIN_ACTION}">
<div id="login_h" style="display: none;">
{IMG_THL}{IMG_THC}<img style="padding-top:3px;float:right;cursor:pointer;" src="{IMG_MAXIMISE}" onclick="javascript:ShowHide('login','login_h','login');" alt="{L_SHOW}" /><a name="login"></a><span class="forumlink">{L_LOGIN_LOGOUT}</span>{IMG_THR_ALT}<table class="forumlinenb" width="100%" cellspacing="0" cellpadding="0">
<tr><td>&nbsp;</td></tr>
</table>{IMG_TFL}{IMG_TFC}{IMG_TFR}
<div id="login">
tmp = 'login';
if(GetCookie(tmp) == '2')
    ShowHide('login', 'login_h', 'login');
</script>
{IMG_THL}{IMG_THC}<img style="padding-top:3px;float:right;cursor:pointer;" src="{IMG_MINIMISE}" onclick="javascript:ShowHide('login','login_h','login');" alt="{L_HIDE}" /><a name="login"></a><span class="forumlink">{L_LOGIN_LOGOUT}</span>{IMG_THR}<table class="forumlinenb" width="100%" cellspacing="0" cellpadding="0">
     <td class="row1" align="center" valign="middle" height="28"><span class="gensmall">&nbsp;{L_USERNAME}:
       <input class="post" type="text" name="username" size="10" />
       &nbsp;&nbsp;&nbsp;{L_PASSWORD}:
       <input class="post" type="password" name="password" size="10" maxlength="32" />
       <!-- BEGIN switch_allow_autologin -->
       &nbsp;&nbsp; &nbsp;&nbsp;{L_AUTO_LOGIN}
       <input class="text" type="checkbox" name="autologin" />
       <!-- END switch_allow_autologin -->
       &nbsp;&nbsp;&nbsp;
       <input type="submit" class="mainoption" name="login" value="{L_LOGIN}" />
       </span> </td>
</form>
<!-- END switch_user_logged_out -->
Edited by Zuker, Sat 14 Apr, 2007 14:54: rounded corners
Thanks for the useful Topic Zuker:
ThE KuKa (14 April), BEN-HUR (17 April), tiolalu (09 June), Sparok (10 June), KugeLSichA (10 June), coolguy14783 (12 June), spirit2 (07 August), uttejona (10 August)
Post Re: Create a login box at forum index
First post updated
