Post A PROBLEM WITH A TEMPLATE!!!
I have a problem with my template:
Friend's template:
sinttulo-2
My template:
sinttulo-1
My friend say me I have to edit 3_column.tpl and I edit but the problem continue. If you see the two templates are the same, but with other color.
ZeTa - View user's profileSend private message
Post Re: A PROBLEM WITH A TEMPLATE!!!
this problem happens only with THIS template?
sonoangelo - View user's profileSend private messageVisit poster's website
i have only this template installed
ok, try to go on cms page, and edit the blocks setting of the blocks that are displayed bad (CMS > 3_columns.tpl > ) setting up all margins option to YES.
if don't work in this way, i don't know more how to help you
PS. WONDERFUL TEMPLATE
if I change I do see any result
My friend say me I have to modify 3 column but he dont want to help me more...
ZeTa wrote: [View Post]
The CMS should do everything that editing 3 column.tpl will.
CivUnited
tonyf12 - View user's profileSend private messageVisit poster's website
did you emptied your cache?   and reuploaded all the correct files?
Hi
As the layout page doesn't have the code for the images they are not going to show... as your friend said you will need to edit 3 column.tpl unless you haven't copied over the correct file for the theme...
I solve it. I had to edit style_ice.css
