Wat I mean is when there is a post you can gife this as a announced or spot or Uploading or upload done or finished, no suport
anounced====> icon ?
spot====> icon *
uploading===> icon >
upload done===> icon V
finished ,no sup===> icon X
That is the status for the posting
Sow I post somthing in the forum and gife this the status Anounced sow there wil be seen on this post by een icon that dis post is a anounced ( ?) or whate te sign wil be
hoop that you can do somthing withe this Mighty Gorgon
Re: Topic Icon
Something similar has been already implemented but it is hidden... you can try to look in the cfg of the theme and in viewforum.php... the code should be there, you need only to enable it.
The time now is Mon 22 Dec, 2025 09:52 • All times are UTC + 1 Hour
