Post Underline And Overline
I have Macintosh...
The problem is the text decoration of the Menu items: Main links, News, Info, User&Groups, RSS.
In Safari they are overlined.
In Camino they are simply underlined.
I'd like to use the second one view for all browsers... what have I to do?
feelbeenSend private messageVisit poster's website
Post Re: Underline And Overline
On this page also the error happend?
Mighty told me yesterday that he fix that thing
Zuker wrote: [View Post]
I don't know what you mean saying "on this page"...
Also on www.icyphoenix.com I see the menu bar overlined... with Safari...
I don't know why... but I thought it was something about style configuration...
post some screenshots
CivUnited
tonyf12Send private messageVisit poster's website
tonyf12 wrote: [View Post]
This is what I mean...
My visualizzation on Safari...
safarimo9
Thanks for reporting it. I thought that opera works liek safari ( i check safari compatibility with opera) but it isn't in this case:S
no problem... so maybe is a style mystake???
feelbeen wrote: [View Post]
I think underline is probably slightly misspelled in that theme's style sheet and most browsers recognise the mistake and correct it but Safari thinks overline is correct.
CivUnited
so I can't resolve this problem???
it will be fixed on next release
ok.. thank you!
I think you should use a Windows PC.
I'm kidding of course.
Unfortunately I cannot test your problem because I don't have a Mac and Safari. I hope that someone having this config may help us in fixing the CSS.
Currently I have removed the underlining.
I try to give look to the .css but I'm starting with php and I can't do anything... first I thoght it was enough to change the text decoration of the dynamic menu from overline to underline... but then I saw that with another browser (like Camino) all works well...
I'll upgrade to final release.. so... that's all!
you are talking about the final release, isn't it?
OT. Mio caro Luca non so perchè pensavo avessi Macintosh... forse perchè ti considero una mente "elevata"...
Colgo l'occasione per ringraziarti nuovamente (come ho fatto via mail) per il tuo lavoro... ti ammiro molto... Complimenti!
Yes I've removed the decoration in the final release, because it wasn't really needed there. But it's not the way to solve problems and we should understand why it is not working fine.
_____________
Grazie per gli apprezzamenti. Uso Windows da sempre, ed onestamente mi sono sempre trovato bene... sia per lavoro che per passione purtroppo Win ha delle cose a cui non posso rinunciare...
Yes... I know that...
_____________
magari un giorno ne parleremo assieme... solo perchè non credo tu debba rinunciare a niente...
