Post Cookie Troubles
Hello.
I have this problem.
 in My Forum i Had a Little problem. the users where desconected  every minute. when i was looking for what was wrong i've changed this option in my ACP:
Cookie secure: Enabled
After that.  I Cant Login into my forum, no one can, i've tryed to enter the ACP but Every time i try to login, my froum just wont open.
My Web URL: http://madison.uni.cc
I have intalled Icy Phonix
I have no Mod installed other than the default ones
than u all. and excuse me if i have not write some infomation needed and my lame english
D1n3e2Send private message
Post Re: Cookie Troubles
you must install the autocookie mod. It work
I have Cookie secure: disabled
Webmaster: EliteMoviles
Server: Sotem.es
Version: Icy Phoenix 1.2.0.27
AexoSend private messageVisit poster's website
Try to execute this query on your SQL:
UPDATE `phpbb_config` SET `config_value` = '1' WHERE `phpbb_config`.`config_name` = 'cookie_secure' LIMIT 1 ;
Keep in mind that you should replace "phpbb" part with database prefix of your own Icy installation (phpbb_ is the default prefix).
After that, clear cookies in your browser, then try to login again.
Omarska online
omarskaSend private messageVisit poster's website
omarska wrote: [View Post]
I did it, but still don't work
Sorry, my mistake. I gave you query that doesn't change anything, because your cookie is already set as secure.
Right query is:
UPDATE `phpbb_config` SET `config_value` = '0' WHERE `phpbb_config`.`config_name` = 'cookie_secure' LIMIT 1 ;
This will set your cookie to non-secure, and after clearing browser cache, you should be able to login.
Sorry one more time
Omarska online
don't be sorry, thank you 4 helping
i've done it, but still don't work
Please Help Me  :10k_0006:
Read this topic please
http://www.icyphoenix.com/viewtopic.php?t=1080
I've read that topic, i read it before opening this one, i've tried what it sais but it still does not work
Have u clean your browser cookies?
I can't access to your forum so i cannot check :S
Yes i have clean it.
It does open but it takes too long! besides when i try to login to change the configuration, but don't open, No one can get login
Since you have lot's of problem with your server i cannot try to login or register to test :S
You can't use secure cookies on not secured server.
Try to run this:
UPDATE phpbb_config SET config_value = '0' WHERE config_name = 'cookie_secure';
Then go here:
http://madison.uni.cc/adm/erc.php
And empty cache and session.
Then empty your browser cache and reset cookies.
Let me know.
First of all thanks for the answer.
I've done it all, but notting works, i guess the only way is to shut it down
Thank you for your Hep
