Post CBACK CrackerTracker SECURITY ALERT
I have Icy Phoenix 1.1.0.15
I have installed CHARTS mod (my forum). when i try to insert a new song, I have this error:
SECURITY ALERT » » » »
CBACK CrackerTracker has detected a potential attack on this site with a worm or exploit script so the Security System stopped the script.
If you can see this page after including a new MOD into your board or after clicking on a link please contact the Board Administrator with this error message and a description what you have done before you could see this page, that the Admin has the possibility to fix the problem.
Gianni PBSend private messageVisit poster's website
Post Re: CBACK CrackerTracker SECURITY ALERT
Gianni PB wrote: [View Post]
Can you post a link to the mod?
There are some file to "certify" before
[img]http://www.mediomondo.it/appoggio/yuqlogo.jpg[/img]
Antonio MercurioSend private message
this is the mod
forumcharts.zip
Description: charts mod
Filename: forumcharts.zip
Filesize: 20.43 KB
Downloaded: 311 Time(s)
this is the mod
Have you tried with the debug option of CT?
Do this:
open ct_security.php located inside ctracker/engines/
find the line
  1. define('CT_DEBUG_MODE', false);
  2.
and replace with
  1. define('CT_DEBUG_MODE', true);
  2.
(don't care for the message on home)
do the same operation that make arise the error and look the debug log.
(write here)
edit again the file and restore the changes you made to the line
I don't know why, but now it works...
Post Re: SOLVED - CBACK CrackerTracker SECURITY ALERT
With debug on?
Yuri MenzlSend private message
