I have problem i think, i can see the theme in the package and in my IP_root but I can see that in the ACP , i can´t install the theme.. whats can be wrong ?? I have same problem with danilo´s theme "dark"
Autumn theme should already be installed or you can simply install it from templates manager in ACP.
For the dark style, how did you try to install it?
Did you edit mg_themes.cfg and theme_info.cfg . And make sure you have the correct number (so you didn't leave it as $mg_themes[x] or put twoas $mg_themes[2] or something)
The time now is Tue 26 Aug, 2025 13:58 • All times are UTC + 1 Hour [DST enabled]
