Post Chatters In ViewOnline Block
Hello again!
Is there any way to view who is chatting in ajax chat in viewonline block at the bottom of  my forum?
Edited by borbo, Fri 25 May, 2007 03:02: more specific
borboSend private message
Post Re: Chatters In ViewOnline
anybody??? Please?
Post Re: Chatters In ViewOnline Block
It is possible, but I don't have the time to code it right now...
Maybe it will be useful to create a full viewonline block for the CMS (currently there is a simple one).
It's not difficult, I hope someone will try...
U mean something like this?
viewonline_ajax
Don't pay attention because user "Zuker" it's in viewonline, that's because i was taking the shot.
I was in ajax chat with test user
I made it i think, but i dunno how to separate nicks by commas
I use
($username . ", ")
at the moment
hmmm I ment sobething very close to this...
I'd like to add the "who is chatting" block somewhere in the portal ot in the forums main pge...
Soorry for being so late...
So you mean a block
I'll play with it tonigh
try this block and let me know
ajax_chat_viewonline.rar
Filename: ajax_chat_viewonline.rar
Filesize: 1.73 KB
Downloaded: 264 Time(s)
Wow...Thanks Zuker...Downloading !
I'll let you know!
It's working fine...Thanks Zuker you the man!
Off Topic
Please check this if you can help? http://www.icyphoenix.com/viewtopic.php?t=2195
You are welcome borbo
i hope someone will help you there <:)
i've tried but i get this:
Template->make_filename(): Error - template file not found: blocks/ajax_chat_viewonline_block.tpl
*blocks_imp_ajax_chat_viewonline.php
*ajax_chat_viewonline_block.tpl
both files are installed in /portal/blocks/
any idea?
sorry for my english
vdpSend private message
you must install ajax_chat_viewonline_block.tpl  in ip_root/templates/mg_themes/blocks/
hplSend private messageVisit poster's website
Sorry, I have this php code to see who is in chat (using Flash Chat)
How can I insert it into Icy?
<?php
/* Flashchat block              */
/* By: Ice2003                                          */
/* Copyright  2005 and Beyond by Ice2003                */
global $DB;
$flashchatprefix = "phpbb_fc";  //Edit this to refelect the prefix of flashchat ie _fc_ or smf_fc_ ect,ect
// Don't change anything under this line or your server will self destruct :)
$curchat = "Current Chat Rooms";
$chatrooms = "Chat Rooms ";
$amtchatters = "Current Chatters";
// ok lets count how many rooms are available
$result = $DB->query("SELECT * FROM ".$flashchatprefix."rooms WHERE ispublic IS NOT NULL");
$files = $DB->get_num_rows($result);
// How many chatters are currently yacking in the rooms
$result = $DB->query("SELECT userid, state, color, lang, roomid FROM ".$flashchatprefix."connections WHERE userid IS NOT NULL");
$cats = $DB->get_num_rows($result);
$content .="<center><img src='$sitepath/.../rooms.gif'></center>";
$content .= "&nbsp;&nbsp;$chatrooms: <b>$files</b><br>&nbsp;&nbsp;$amtchatters: <b>$cats</b><br></b>";
$content .="<center><img src='$sitepath/.../users.gif'></center>";
// Lets print out a list of the rooms for all to see
$content .= "<center><b>".$curchat."</b></center>";
$a = 1;
$result = $DB->query("SELECT id, name FROM ".$flashchatprefix."rooms WHERE ispublic IS NOT NULL");
while(list( $id, $name) = mysql_fetch_row($result)) {
        $title2 = ereg_replace("_", " ", $name);
      $content .= "&nbsp;&nbsp;$a- <a href="/forum/chat/flashchat.php?lang=en&room=$id">$title2</a><br>";
        $a++;
unset($result);
unset($cats);
unset($files);
// yeaaaaa its the php end thingy it means i have finished
...and I didn't understand how to write the .tpl......
Edit:
sorry for writing in italian, I traslated. I visit both forums and I have italian language on both, so I got confused
LabiriSend private message
Please visit icyphoenix.it for italian support
I'll check this... good work Zuker!
