Post Ctracker Makes A Lot Of Problems
Hello everyone,
got a important question. I saw some solutions for the CBack CrackerTracker Errors but there was nothing in my case.
I have downgrate phpbb plus to phpbb and than upgrated to Icy Phoenix at first I didn#t notice but Ctracker don't let me change anything in profile éven if I try to change the country it always tell me the ctracker error and now I was wondering how the ctracker is included in the Icy Phoenix board is it just impalted or included as referrer in every file?
Sorry for my bad english ^^
THX for your help
deejaymoni - View user's profileSend private messageVisit poster's website
Post Re: Ctracker Makes A Lot Of Problems
I have fixed the problem now on my own.
I should define('CT_SECLEVEL', 'MEDIUM'); for an mod called "Custom Profile Fields". Just run Ctracker in debug mod.
Post Re: SOLVED - Ctracker Makes A Lot Of Problems
Thank you very much for posting the problem and the solution as well.
Can you please tell us where did you add that string?
Thank you.
Find in profile.php
include($phpbb_root_path . 'common.' . $phpEx);
Add before
$ct_ignorepvar = array('interests','your_favourite_jessica_movie_','why_do_you_like_jessica_'); <-- this depends on the settings of the Custom Profile Fields Mod.
So better try Ctracker in debug mode to know exactly how the syntax need to be written.
