Post Possible To Get This Effect When Enlarging Pictures?
Hi there, I was wondering if it's possible to get this effect when you enlarge your pictures in the FAP?
Click on the picture in the link to see the effect that I want.
Link:
http://bintang.klgate.com/index.php...id=88&Itemid=28
Fabiomaticus - View user's profileSend private messageVisit poster's website
Thanks for the useful Topic Fabiomaticus:
Mighty Gorgon (16 December), CemetaryMan (26 December)
Post Re: Possible To Get This Effect When Enlarging Pictures?
Yes, you can get the script at http://www.huddletogether.com/projects/lightbox2/
Place the code to include the javascript and css files at the top of templates/YOUR TEMPLATES/album_showpage_body.tpl
For the active link:
OPEN album_showpage.php
'U_PIC_L1' => ( $picm == false ) ? '' : '<a href="' . append_sid(album_append_uid('album_showpage.' . $phpEx . '?full=true&amp;pic_id=' . $pic_id . $nuffimage_vars)) . '">',
     'U_PIC_L1' => ( $picm == false ) ? '' : '<a href="album_mod/upload/'.$thispic['pic_filename'].'" rel="lightbox" title="'.$thispic['pic_title'].'">',
Artie - View user's profileSend private messageView user's personal gallery
thx artie,
i like it too and try it later.
Play Games at GamesCampus!
Great thing,
thanks Artie
Artie have you tested this?
i edited my file and added the lightbox part 1 in my album_showpage.tpl but its not working... i get a error 404 O_o
Yes, I've been using it for some time on a standard phpBB board. It was a long time ago, but I don't think I did anything special to get it to work. I'll check when I get a chance.
You may have to adjust the included script paths (Part 1) to point to your lightbox directory.
I haven't tried it on Icy Phoenix .... I'm sure it should work, but you will have to change the U_PIC_L1 path (Part 2) for sure.
Hmmm... Nothing comes up when I click the image.
It's just keeps thinking forever and ever.
Any idea what could have gone wrong?
Go here:
h**p://***.themagiciansknob.com/album_showpage.php?pic_id=36
Ok, I think I know what the problem is... I can't seem to find my uploaded pictures. I can't load a single picture in the browser. It's very wierd and I don't know why.
What I mean by this is that I can't link directly to a picture.
ie.
h**p://***.themagiciansknob.com/alb...fc416586703.jpg
ie2.
h**p://***.themagiciansknob.com/alb...7579dd5e538.gif
Greve - View user's profileSend private message
Delete htaccess
Please i have download the lightbox.
There are the folder: images, css, js
where do I have to copy them?
I have add in album_showpage_body.tpl these three lines:
<script type="text/javascript" src="js/prototype.js"></script>
<script type="text/javascript" src="js/scriptaculous.js?load=effects"></script>
<script type="text/javascript" src="js/lightbox.js"></script>
But don't fuction!
Fabiomaticus wrote: [View Post]
But don't fuction!
I guess it is not enough for that lightbox to work.
You should then insert it in thumbnails IMG tags something I guess.
Create a folder called lightbox in you phpbb_root.
Add these lines to the template file
<script type="text/javascript" src="lightbox/js/prototype.js"></script>
<script type="text/javascript" src="lightbox/js/scriptaculous.js?load=effects"></script>
<script type="text/javascript" src="lightbox/js/lightbox.js"></script>
<link rel="stylesheet" href="lightbox/css/lightbox.css" type="text/css" media="screen" />
and edit album_showpage.php as mentioned above.
Artie,
I got these modifications working on my forum album. What if I wanted to choose "View full pic as a popup". What would I have to modify to make the link for the popup point to the lighbox feature instead?
Thanks in advance for any help you can offer...
Tahoebuff
Tahoebuff - View user's profileSend private message
Tahoebuff wrote: [View Post]
Artie,
Tahoebuff
I guess it would be enough to add the include for the .js and .css files to the overall_header.tpl
and you would probably have to make the  change below to several album php files. (album.php, album_cat.php, and others)
'TARGET_BLANK' => ($album_config['fullpic_popup']) ? 'target="_blank"' : '',
//'TARGET_BLANK' => ($album_config['fullpic_popup']) ? 'target="_blank"' : '',
        'TARGET_BLANK' => ($album_config['fullpic_popup']) ? 'rel="lightbox"' : '',
You guessed right Artie
The only other file I had to make the change in was album_personal.php
Thanks a million...
Tahoebuff
