Post Amending Copyright Info In Footer
To try and reduce the number of spammers who may may search for terms like 'Icy Phoenix' and also 'phpBB', is it possible to replace the copyright section in the fotter with an image showing the same copyright info?
I understand that I'd lose info like Page Generation Time: 1.5621s (PHP: 98% SQL: 2%) SQL queries: 11 - Debug On - GZIP Enabled etc....
tc1967uk - View user's profileSend private message
Post Re: Amending Copyright Info In Footer
tc1967uk wrote: [View Post]
Of course you can.
Can anyone help, in how to actually remove the footer section and replace it with an image instead?
do u have the image?
I've just created one that may look ok.  It would need to be central on the footer.  Is it possible to have a similar image (without text) that would tag on at each end that could fill up the width of the page?  I'll attach one for that one just in case.
Thanks for looking at this, Zucker.
Filesize: 263 Bytes
Viewed: 2396 Time(s)
Filesize: 6.63 KB
Zuker (or anyone), any ideas on how to implement this?
Go in overall_footer for the template and add the image in.
Press 22 - View user's profileSend private message
I should explain - I'm no good with php.
Can someone tell me please:
A)  What code I would need to add to insert a graphic in the middle of the footer, plus a graphic either side of that to fill up to the side of the page no matter what size it was
B)  What code I should take out to remove all the text that appears normally in the footer.
its not php in that file
It's basic html.
Thanks, but that doesn't help me either.  Can anyone help with what I actually need to do?
sorry brother
i'll play with it in a minutes
in your overall_footer.tpl
replace
        <table class="empty-table" width="100%" cellspacing="0" cellpadding="0" border="0">
                <td nowrap="nowrap" width="250" align="left">
                    <span class="copyright">&nbsp;Powered by <a href="http://www.icyphoenix.com/" target="_blank">Icy Phoenix</a> based on <a href="http://www.phpbb.com/" target="_blank">phpBB</a>{TRANSLATION_INFO}</span>
                </td>
                <td nowrap="nowrap" align="center">
                    <div style="text-align:center;">
                        <span class="generation"><b>{LOFI}</b></span>
                        <!-- BEGIN generation_time_switch -->
                        <span class="generation">{PAGE_GEN_TIME} <b>{GENERATION_TIME}s</b> (PHP: {PHP_PART}% SQL: {SQL_PART}%)</span><br />
                        <span class="generation">{SQL_QUERIES}: {NUMBER_QUERIES} - {DEBUG_TEXT} - {GZIP_TEXT}</span>
                        <!-- END generation_time_switch -->
                </td>
                <td nowrap="nowrap" width="250" align="right">
                    <span class="copyright">Design by <a href="http://www.mightygorgon.com" target="_blank">Mighty Gorgon</a>&nbsp;</span>
                </td>
        </table>
with
                <td nowrap="nowrap" width="250" align="center" background="link of bg image">
                    <a href="www.icyphoenix.com" target="_blank"><img src="link of text image"/></a>
                </td>
        </table>
notice that you have to replace
link of bg image and link of text image
Thanks Zuker, it worked great on Firefox, but the text image isn't centred in IE.  Any ideas?
Hi
try this
<div align="center">
    <table class="empty-table" cellspacing="0" cellpadding="0" width="100%">
                <td nowrap="nowrap" align="center" background="link of bg image">
                    <img src="link of text image" border="0"/></a>
                </td>
        </table></div>
Pepi
pepi - View user's profileSend private messageVisit poster's website
add align="center" to the table & img
        <table class="empty-table" align="center" width="100%" cellspacing="0" cellpadding="0" border="0">
                    <a href="www.icyphoenix.com" target="_blank"><img src="link of text image" align="center"/></a>
                </td>
        </table>
Post new topic  This topic is locked: you cannot edit posts or make replies.  Page 1 of 2
