Post Mulitple Ranks Mod
I have the Multiple ranks successfully installed and it works great! BUT, I do have a few questions:
1. Is there a way to make the ranks appear horizontially instead of vertically? I would love to have the ranks appear stacked together horizontially, instead of vertically in viewtopic, memberlist and profile.
2. Is there a way to make the title of the rank go away? I do not need the titles of the ranks/icons, can I remove them?
3.Is there a simple way to add a few more ranks than what comes with the mod?
My website is ***.milsimempire.com/forum
Thank you in advance,
DAT116
DAT116Send private message
Post Re: Mulitple Ranks Mod
DAT116 wrote: [View Post]
My website is www.milsimempire.com/forum
DAT116
Hi DAT116,
  1. Yes it is possible, you need to remove the <br /> from this code in each of this code:
            $user_rank_01 = ($user_ranks['rank_01'] == '') ? '' : ($user_ranks['rank_01'] . '<br />');
            $user_rank_01_img = ($user_ranks['rank_01_img'] == '') ? '' : ($user_ranks['rank_01_img'] . '<br />');
            $user_rank_02 = ($user_ranks['rank_02'] == '') ? '' : ($user_ranks['rank_02'] . '<br />');
            $user_rank_02_img = ($user_ranks['rank_02_img'] == '') ? '' : ($user_ranks['rank_02_img'] . '<br />');
            $user_rank_03 = ($user_ranks['rank_03'] == '') ? '' : ($user_ranks['rank_03'] . '<br />');
            $user_rank_03_img = ($user_ranks['rank_03_img'] == '') ? '' : ($user_ranks['rank_03_img'] . '<br />');
            $user_rank_04 = ($user_ranks['rank_04'] == '') ? '' : ($user_ranks['rank_04'] . '<br />');
            $user_rank_04_img = ($user_ranks['rank_04_img'] == '') ? '' : ($user_ranks['rank_04_img'] . '<br />');
            $user_rank_05 = ($user_ranks['rank_05'] == '') ? '' : ($user_ranks['rank_05'] . '<br />');
            $user_rank_05_img = ($user_ranks['rank_05_img'] == '') ? '' : ($user_ranks['rank_05_img'] . '<br />');
  2. Yes it is possible, you need to remove the rank title from each template file:
    {memberrow.USER_RANK_XX}
  3. Sorry, I can't understand what do you mean... would you like to increase the numbers of ranks (more than 5) or add more graphics?
Hi there !!
I think I have the same problem but what I want to know is which file I have to modify this line:
thx in advance !
KaTHoOSend private message
That is in memberlist_body.tpl, but you have to remove similar occurrences in viewtopic_body and profile_view_body as well.
Many thanks Luca !
You are welcome.
You are welcome.
Hello i have a question, for the multiple ranks 2.0.3 version for phpbb2 how come i keep getting a parse error in the profile and memberlist area i get this kind of error:
Parse error: syntax error, unexpected '[' in /home/timeless/public_html/forum2/includes/functions_mg_ranks.php on line 44
Can you please help me, thanks
ttreasuresSend private message
