I would modify the "blue" bar that appear on the top of the site when you are using ICE template, I mean the bar where there is the logo and the advertising.
How can I do it ? what is the to be modified ?
Thank you ...
The time now is Sun 03 Aug, 2025 00:14 • All times are UTC + 1 Hour [DST enabled]
