Calendar Problem
In ACP > config > Calendar settings I have "Display the calendar row on the board header" set to YES, but the calendar rows don't appear above the forums list in viewforum page, is there something else I should check?
The number of rows there should apear?
I think all is set correctly, but as you can see nothing appears:
Vortex, I have the same problem, finally IcyPhoenix work on my test server (when I have some time I will explain my problem and haw to solve it)
I have tried to "enable" calendar but it doesn't appears on the board ...
I have tried to change Style to Aprodite and it works fine, all tests gone well.
So I have tried to add calendar functionality to MG themes but withouth good results (I'm a programmer but my knowlege of PHP and CSS is basic) ...
Work in progress ...
The time now is Mon 20 May, 2013 03:44 • All times are UTC + 1 Hour [DST enabled]
