Post Account Suspended - WHB
Dear Customer,
Unfortunately we had to suspend your account 'elmatasa' on
 milkyway.whbdns.com for server resource abuse. Please see related stats below. Your
 account may be unsuspended in case you'll agree to take measures in
 order to reduce load. If nothing can be done about this, you should
 consider upgrading your account to dedicated or semi-dedicated.
[root@milkyway ~]# ps aux | grep elmatasa
elmatasa  2852  7.7  0.0      0     0 ?        Z    16:26   0:00 [php]
 <defunct>
elmatasa  2871 37.0  2.7  87112 56832 ?        R    16:26   0:00
 /usr/bin/php UCP.php
elmatasa  2872 36.0  3.2  87104 67356 ?        R    16:26   0:00
[root@milkyway ~]# ps -u elmatasa -fH eeww
UID        PID  PPID  C STIME TTY      STAT   TIME CMD
elmatasa  2381  9914  0 16:25 ?        R      0:00 /usr/bin/php UCP.php
 PATH=/usr/local/bin:/usr/bin:/bin CONTENT_LENGTH=104
 CONTENT_TYPE=application/x-www-form-urlencoded
 DOCUMENT_ROOT=/home/elmatasa/public_html/casimedicos HTTP_ACCEPT=image/gif, image/x-xbitmap, image/jpeg,
 image/pjpeg, application/x-shockwave-flash, */* HTTP_ACCEPT_ENCODING=gzip,
 deflate HTTP_ACCEPT_LANGUAGE=es-es HTTP_CACHE_CONTROL=no-cache
 HTTP_CONNECTION=Keep-Alive HTTP_COOKIE=ksibb3_agosto07_u=5735; ksibb3_agosto07_k=;
 ksibb3_agosto07_sid=d2b7a9f3cab1b48ea8695c7f22cca2fd;
 __utma=8515495.766425619.1190138411.1190201295.1190205482.4;
 __utmz=8515495.1190138411.1.1.utmccn=(direct)|utmcsr=(direct)|utmcmd=(none)
 HTTP_HOST=www.casimedicos.com
 HTTP_REFERER=http://www.casimedicos.com/foro/2007/UCP.php?i=profile&mode=avatar
 HTTP_UA_CPU=x86 HTTP_USER_AGENT=Mozilla/4.0 (compatible; MSIE 7.0; Windows
 NT 5.1; .NET CLR 1.1.4322; FDM; .NET CLR 2.0.50727)
 REMOTE_ADDR=84.124.0.17 REMOTE_PORT=2455
 SCRIPT_FILENAME=/home/elmatasa/public_html/casimedicos/foro/2007/UCP.php SERVER_ADDR=69.72.215.202
 SERVER_ADMIN=webmaster@casimedicos.elmatasanos.com SERVER_NAME=www.casimedicos.com
 SERVER_PORT=80 SERVER_SOFTWARE=Apache/1.3.37 (Unix)
 mod_auth_passthrough/1.8 mod_log_bytes/1.2 mod_bwlimited/1.4 FrontPage/5.0.2.2635.SR1.2
 mod_ssl/2.8.28 OpenSSL/0.9.8b PHP-CGI/0.1b GATEWAY_INTERFACE=CGI/1.1
 SERVER_PROTOCOL=HTTP/1.1 REQUEST_METHOD=POST
 QUERY_STRING=i=profile&mode=avatar REQUEST_URI=/foro/2007/UCP.php?i=profile&mode=avatar
 SCRIPT_NAME=/foro/2007/UCP.php
Regards,
Alexey K.
Technical Support Team
WebHostingBuzz.com
WHB Networks LLC *Hosting Wakeup Call*
url http://www.casimedicos.com/foro/2007/
script phpbb3 rc5
as i understand the problem is UCP.php
someone can help me i do not understand the information on this email
thanks
jack of all trades, master of none
http://www.mieloma.com/ - http://www.casimedicos.com/ - http://www.egalego.com/ - http://www.casimedicos.com.es/ - http://www.medicosmir.com/
casimedicosSend private messageVisit poster's website
Post Re: account suspended - whb
I guess you should disable any avatar uploading or linking features.
I would change hosting... as you see it's not a matter of Icy Phoenix being resource waster... it is a matter of a host with really restricted policies.
I guess that getimagesize is the problem for them...
I'll stop here... I don't want to become rude.
yes it is
i hate hosting companies
thanks
i found this free
http://elixarweb.com/
i try to deactivate all avatars
Post Re: Account Suspended - WHB
I had the same problem too but on the sitemap.php file that it was using too much CPU. but they gave me a warning and told me to delete the file. so i did. and made a new generated sitemap.xml file to keep it.
NiroseSend private messageVisit poster's website
