Post How To: Change Domain And Icy Phoenix's Upgrade
Hello,
i'm changing my forum's domain (from www.bambinacattiva.com to www.nightportal.it)and i'd like to know how to upgrade it from 1.0.11.11 to 1.1.0.15b.
I need to know how make a database's backup and move it to the new domain, all this by using MySql/PhpMyAdmin(please show me how to manage the settings to importexport...as the attached image do...even if it is in italian).
Thanks and congratulation for your awesome work.
Greetings
Bambina Cattiva's Staff.
Filename: phpmyadmin.jpg
Filesize: 178.46 KB
Downloaded: 230 Time(s)
Bambina CattivaSend private messageVisit poster's website
Post Re: How To: Change Domain And Icy Phoenix's Upgrade
You are edit all data base for the new domain later install ICY and upgrade
? JHOSMAN - Webmaster
JHOSMANSend private messageVisit poster's website
  1. Just copy the files if you modified something, except the config.php, it contains the sql data.
  2. Then go to the ACP and change your site status closed and then change your site url and the relative route if needed.
  3. Export the db and store if in your hd.
  4. Just re-upload the icy backup in your new site. (upload the install files too, you´ll need them)
  5. Last: Restore your db. Go to ACP and open your site again.
  6. Enjoy!
The second point and the second part of the last intructions is the only to do if you have the same db and relative route from your domain/subdomain.
