Post Icy Phoenix 1.1.7.22a RC 1
Hi all,
after some extra live tests on several sites, I've decided to go with RC 1 of Icy Phoenix.
What's New respect to Icy Phoenix 1.1.0.15
  • Groups system: the old color group mod has been dropped and a new system has been recoded to make groups management close to phpBB 3 way.
  • CMS features: now it is possible to assign blocks on single pages, not only as global blocks, but as specific blocks. It is possible also to duplicate blocks from others layout.
  • Save as draft: it is now possible to save posts and PM as drafts. The function is similar to phpBB 3 one, but much more simpler and with less features.
  • Caching images: all images are now sent in cache, even external ones. A direct link is then included in the post for saving CPU charge (despite of more disk usage). This will speed up Icy Phoenix a bit, especially for those servers that don't like getimagesize PHP function. Only dynamic images won't be cached.
  • New Downloads System: since I need this pack for an extra work, I've decided to integrate it in Icy Phoenix so you can use it in conjunction or alternatively to PA File DB. There is no link for this, but you can choose in constants.php where download link should point to. This feature it is still under test, and currently it is configured to not use any extra SQL charge to the package. (Because I've disabled features who where SQL consuming for Icy Phoenix).
  • Pages sessions: phpBB 3 has a much more flexible pages sessioning system, allowing better tracking of what users do. In Icy Phoenix I have partially replicated it, by modifying the way sessions work.
  • Actions logs: I have coded a small and simple logging system which stores on files all the actions performed by users which alter in some way the DB. The logs are difficult to read, so it is disabled by default and the switch to enable it is hidden. If someone is interested in I may show how to enable it... but I won't help in reading it, because it is tough for who doesn't know PHP, and how requests are made.
  • Extra stuff not enabled by default and not supported: since many of you requested integration of Cash and Activity, I have decided to integrate this in Icy Phoenix, and I will continue to keep them updated as the release is going on... but no support will be given with these extra features.
  • Templates: some small adjustments have been applied to the templating system to make it a bit more flexible and some new templates designed by me will be available with this release.
  • Extra BBCodes: there are now extra BBCodes you can use to format your posts... as soon as I have the time I will include some demos. Plus there is now a random number generator.
  • Extra debugging: phpBB 3 has a cool debugging feature which tells you the queries of each page and the time used for them. I've tried to enhance this feature a bit including some extra info and memory usage. This will be tremendously helpful for those webmasters who wants to understand the entity of Icy Phoenix charge and settings. Extra info about the usage of this feature, will follow.
  • Small fixes and adjustments: several small fixes and adjustments have been applied to the package. I don't have a full list of them, but you will notice some changes somewhere... I hope you will appreciate it. Just some of them: resend registration, remove cookies, album rss, new thumbnails functions.
  • Security fixes: unfortunately I've found during the dev phase some extra security holes which I have fixed the most risky in the available patch for 15b, but two of them which I was unsure, have been recoded differently to minimize infection risk.
Older templates: Please note that templates designed for 1.1.0.15 won't work fine with this version. All older styles have to be updated before using them. I will try to show template creators the way the may follow to upgrade their templates.
Support
For release candidates almost full support is given, especially to those people helping with language packs and templates creations.
As usual, no code changes will be released, and won't probably be released for any version in the future. This is because the package is quite huge and writing code changes requires much time: as I already said in the past, I prefer to focus my free time on developing the package instead of writing huge code changes that could be difficult to be applied. Trust me, in most cases it is quicker to replace old files with new ones and reapply eventually added mods (you should take note of the mods you have applied). My efforts will be dedicated to the upgrade procedures to allow you to upgrade your sites with the smallest unexpected issues.
Anyway for final release, I'll try to provide a changed files package and a small template changes guide... or at least a list with the changed files for those who have modded their site or released templates. I'll try to give translators a list of changed files as well.
In install folder now you have some extra files you may use to convert your board, delete old files, fix db tables...
  • install.php: this is for brand new installations.
  • update_to_ip.php: this is for upgrading from phpBB or any XS or Icy Phoenix versions.
  • clean_tables_ip.php: if you want to clean up your tables, resetting them to the default Icy Phoenix ones, you can use this files. This file is meant for standard Icy Phoenix, not for modded versions. This file may be used even when upgrading from other platform: phpBB Plus, IntegraMOD, FullyModded... etc. Please note that this action cannot be undone, make sure you have a full db backup before proceding.
  • clean_old_files_ip.php: this files will delete all unused files from previous installations of Icy Phoenix. Please note that this action cannot be undone, make sure you have a full backup of all files before proceding. (This file may not run correctly on some servers configurations)
Available Packages
Since this is a release candidate package, I prefer to release an all in one package which includes in several folders all the extras and templates. I know that this means having a bigger file, but I don't want users trying to install extras in the latest stable release, because with high probability modifications for Icy Phoenix 1.1.0.15 won't work in newer releases, because of the new modifications I made to the core files.
Currently available is only a single big pack.
Package Name: Icy Phoenix
Package Version: 1.1.7.22a RC 1
Release Spot: $mg = new MightyGorgon(); //This instantiate a new MG class
DOWNLOAD: Icy Phoenix 1.1.7.22a RC 1
Enjoy Icy Phoenix!
Thanks for the useful Topic Mighty Gorgon:
JANU1535 (12 November), novice programmer (12 November), hpl (13 November), ThE KuKa (13 November), JuanMtg (13 November), BEN-HUR (13 November), Cristina (14 November), isb1009 (14 November), JHOSMAN (15 November), Harimau (15 November), buldo (15 November), KugeLSichA (16 November), ieio (16 November), ArVeeGee (19 November), Shaythong (25 November)
Post Re: Icy Phoenix 1.1.7.22 RC 1
Thanks MG for your work.
I have try to download the package.
And I have got this message.
The address you have requested is not available on this server. You may have mispelled the address or what you are looking for may have been removed.
Greets.
www.JanuWeb.Com - Webmaster
www.phpBB-Es.Com - Administrador
JANU1535 - View user's profileSend private messageVisit poster's website
great Luca...
i was waiting for the new RC
going to test it now
THANKS! + DANKE!
Play Games at GamesCampus!
Great!  Updating....
~~ novice programmer ~~
novice programmer - View user's profileSend private messageView user's personal gallery
I have a question
This new installation or for me upgrade in my case
Come with some folders like "activity" "lang_italian" and "templates"
This folders are independents of ip_root folder
My question is
How can install this folders?
I don't want a make a mistake so i install only ip_root folder
Please can u help me?
Explain me step by step please if you can
Please
Regards
Edited by brandsrus, Tue 13 Nov, 2007 07:51: Please, write your message next time in normal letters
foxman - View user's profileSend private message
Thanksssss!!!!!!
www.todoPVR.com IP 2.0.0.86 DVB-T PVR's
m740 - View user's profileSend private messageVisit poster's website
Super great!!!
Thank you,
When you have a chance,  would you please let me know there is any other update?  'cause it 's asking for update in my ACP.  I turned it off now so it won't bug me.
xmenfile - View user's profileSend private message
foxman wrote: [View Post]
I have a question
My question is
Please
Regards
If you upload only ip_root it will work.
templates contain the ca_aphrodite theme.
languages contain the italian languages
activity constain the activity mod.
Yes, i understand that but im still don`t know how can install the activity folder for example
this particular folder have a sub-folders like game_root ip_root amod templates and language
im so confused.......
by the way this upgrade is not compatible whit the language spanish pack most recently added
NICE!!! Work Luca
ThE KuKa - www.IcyPhoenix.Es - www.phpBB-Es.COM - www.phpBBMODs.Es
ThE KuKa - Admin Icy Phoenix and Translation Group Leader.
ThE KuKa - View user's profileSend private messageVisit poster's website
Thank you MG
Non c'era la legge sul pericolo...
Cristina - View user's profileSend private messageVisit poster's websiteView user's personal gallery
Many thanks, MG!
~~~ Andrea ~~~
User #379756 on Linux Counter
buldo - View user's profileSend private messageVisit poster's website
This version is avaliable to the Beta 1?
? JHOSMAN - Webmaster
JHOSMAN - View user's profileSend private messageVisit poster's website
JHOSMAN wrote: [View Post]
Yes !
Gr. Ron
Team "Dutch"
?If you have accomplished all that you have planned for yourself, you have not planned enough."
Harimau - View user's profileSend private message
Harimau wrote: [View Post]
Yes !
Ok Thaks
To Update =D
