Post Add A Blank Page
I want to add a blank page: http://www.icyphoenix.com/viewtopic...&p=11376#p11376
But I have this error:
Could not query posts table
DEBUG MODE
SQL Error : 1146 Table 'Sql16333_1.CONSTANT_WITH_THE_NAME_OF_THE_TABLE' doesn't exist
SELECT column_name FROM CONSTANT_WITH_THE_NAME_OF_THE_TABLE WHERE column_operator_value
Line : 26
File : _blankpage.php
Gianni PBSend private messageVisit poster's website
Post Re: Add A Blank Page
That's an old tutorial, the best way to add pages it's using CMS's power
I know, but I don't like it....
So you can try to use this
  1. <?php
  2. define('IN_PHPBB', true);
  3.
  4. $phpbb_root_path = './'; // <--
  5. include($phpbb_root_path . 'extension.inc');
  6. include($phpbb_root_path . 'common.'.$phpEx);
  7.
  8. $userdata = session_pagestart($user_ip, PAGE_INDEX);
  9. init_userprefs($userdata);
  10.
  11. include($phpbb_root_path . 'includes/page_header.'.$phpEx);
  12. ?>
  13.
  14. html code here
  15.
  16. <?
  17. include($phpbb_root_path . 'includes/page_tail.'.$phpEx);
  18. ?>
Save it as a .php file, and place it on the root of tour forum
yes yes thanks...but I want to use template. How can I do it?
Gianni PB wrote: [View Post]
You can use template using Cms or this way, style it's parsed since page_header it's included
if i use CMS, my pages will save on DB?
how does it work?
yes , inside db
i have to add 500 pages....I think my db will not very happy...
is there an other way to add pages with template inside a table?
Zuker wrote: [View Post]
  1. <?php
  3.
  7.
  10.
  12. ?>
  13.
  14. html code here
  15.
  16. <?
  18. ?>
ok, i'll use this..thanks!
