Post MG Autumn For PhpBB3 Logo Problem
I have removed the sitelogo_small.png and all references to it from my board so that I can upload a new banner.
I have set the top_logo.png to repeat from an image of 77 x 5 pixels and that works fine.
I have edited my overall_header.html as follows:
<div id="top_logo">
<td height="77" align="left" valign="top"><a href="http://www.galahscorner.com.au/gumtree/" target="_blank"><img src="http://www.galahscorner.com.au/gumtree/banners/banner.gif" width="800" height="73" border="0" /></a></td>
</table>
Yet even after uploading the new file (I deleted the old one rather than over write it) the sitelogo_small.png and the table it is in still shows up as a red X
I am unable to find any other reference to sitelog_small.png so I am guessing another file is required to be edited in order for it to be removed and my banner to show in it's place.
You can see the current problem at http://www.galahscorner.com.au/gumtree/index.php and I would appreciate some help it resolving this issue thanks.
rodneyangell.com (aka ~HG~)
Methusala - View user's profileSend private message
Post Re: MG Autumn For PhpBB3 Logo Problem
Correct me if I'm wrong... but it seems you already solved it...
No MG I Haven't resolved it as yet but I am still working on it.
The current banner is now top_logo.png with a background color added behind it.
What I now need to do, is to replace the background color with a repeat of the last part of the banner so that it appears normal in all resolutions.
If I use the code that I posted, the banner does not show at all.
So what I need now is the top_logo.png being repeated with the banner installed over the top of it so that appears as one banner no matter what the resolution people are viewing in.
The only thing that I managed to resolve was getting rid of the table and the red X by using the ACP option to refresh the imageset images.
This time it really seems that you solved it... right?
Yes this time I have resolved it so thankyou for your interest and also thankyou for the template design itself.
Great!
You are welcome.
