tiolalu
 Solved - Change Time In The Forum
Hi!
I have change of server, and in the new, the forum shows me the time with 6 hours more than GMT, and all times in server is set to GMT time...
How can I set also the forum to GMT?
Thanks!
#1 Fri 14 Dec, 2007 15:11 |
novice programmer
 Re: Change Time In The Forum
____________ ~~ novice programmer ~~
#2 Fri 14 Dec, 2007 16:06 |
tiolalu
novice programmer, Time Zone = UTC, time that I see on the forum: 6 hours more than GMT.
Also in my profile I have GMT+1 and I see GMT+7.  .
Also that option only change the time of the guests, not of the users. I know, they can change each one the timezone in order to get the real time, but they need to select another country that is 6 hours before.
#3 Fri 14 Dec, 2007 23:59 |
That is a wrong setting of your server... if you don't have access to your server config, ask your host.
#4 Sun 16 Dec, 2007 01:47 |
tiolalu
Mighty Gorgon, when I execute date command in the server it gives me the GMT time... I have asked but no response to that  .
Thanks anyway MG!
#5 Sun 16 Dec, 2007 01:55 |
Can you give me a link please?
#6 Sun 16 Dec, 2007 01:57 |
tiolalu
Mighty Gorgon, www.forov360.com (it's in the WWW icon  )
#7 Sun 16 Dec, 2007 01:59 |
I'm 99% sure that it is a wrong setting on your server.
#8 Sun 16 Dec, 2007 02:01 |
tiolalu
Mighty Gorgon, ok, thanks. But there is not any other way to change it?
#9 Sun 16 Dec, 2007 02:02 |
No because if your server time is set to be 7 o'clock when UTC, then IP cannot understand which is the real time... it gets time from the server.
The only thing you can do for now is changing lang files...
- $lang['-12'] = 'GMT - 12 Hours';
- $lang['-11'] = 'GMT - 11 Hours';
- $lang['-10'] = 'GMT - 10 Hours';
- $lang['-9'] = 'GMT - 9 Hours';
- $lang['-8'] = 'GMT - 8 Hours';
- $lang['-7'] = 'GMT - 7 Hours';
- $lang['-6'] = 'GMT - 6 Hours';
- $lang['-5'] = 'GMT - 5 Hours';
- $lang['-4'] = 'GMT - 4 Hours';
- $lang['-3.5'] = 'GMT - 3.5 Hours';
- $lang['-3'] = 'GMT - 3 Hours';
- $lang['-2'] = 'GMT - 2 Hours';
- $lang['-1'] = 'GMT - 1 Hours';
- $lang['0'] = 'GMT';
- $lang['1'] = 'GMT + 1 Hour';
- $lang['2'] = 'GMT + 2 Hours';
- $lang['3'] = 'GMT + 3 Hours';
- $lang['3.5'] = 'GMT + 3.5 Hours';
- $lang['4'] = 'GMT + 4 Hours';
- $lang['4.5'] = 'GMT + 4.5 Hours';
- $lang['5'] = 'GMT + 5 Hours';
- $lang['5.5'] = 'GMT + 5.5 Hours';
- $lang['6'] = 'GMT + 6 Hours';
- $lang['6.5'] = 'GMT + 6.5 Hours';
- $lang['7'] = 'GMT + 7 Hours';
- $lang['8'] = 'GMT + 8 Hours';
- $lang['9'] = 'GMT + 9 Hours';
- $lang['9.5'] = 'GMT + 9.5 Hours';
- $lang['10'] = 'GMT + 10 Hours';
- $lang['11'] = 'GMT + 11 Hours';
- $lang['12'] = 'GMT + 12 Hours';
- $lang['13'] = 'GMT + 13 Hours';
- $lang['tz']['-12'] = '(GMT -12 Hours) Eniwetok, Kwajalein';
- $lang['tz']['-11'] = '(GMT -11 Hours) Midway Island, Samoa';
- $lang['tz']['-10'] = '(GMT -10 Hours) Hawaii';
- $lang['tz']['-9'] = '(GMT -9 Hours) Alaska';
- $lang['tz']['-8'] = '(GMT -8 Hours) Pacific Time (US & Canada)';
- $lang['tz']['-7'] = '(GMT -7 Hours) Mountain Time (US & Canada)';
- $lang['tz']['-6'] = '(GMT -6 Hours) Central Time (US & Canada), Mexico City';
- $lang['tz']['-5'] = '(GMT -5 Hours) Eastern Time (US & Canada), Bogota, Lima, Quito';
- $lang['tz']['-4'] = '(GMT -4 Hours) Atlantic Time (Canada), Caracas, La Paz';
- $lang['tz']['-3.5'] = '(GMT -3.5 Hours) Newfoundland';
- $lang['tz']['-3'] = '(GMT -3 Hours) Brazil, Buenos Aires, Georgetown';
- $lang['tz']['-2'] = '(GMT -2 Hours) Mid-Atlantic';
- $lang['tz']['-1'] = '(GMT -1 Hour) Azores, Cape Verde Islands';
- $lang['tz']['0'] = '(GMT) Western Europe Time, London, Lisbon, Casablanca, Monrovia';
- $lang['tz']['1'] = '(GMT +1 Hour) CET(Central Europe Time), Brussels, Madrid, Paris';
- $lang['tz']['2'] = '(GMT +2 Hours) EET(Eastern Europe Time), Kaliningrad, South Africa';
- $lang['tz']['3'] = '(GMT +3 Hours) Baghdad, Kuwait, Riyadh, Moscow, St. Petersburg';
- $lang['tz']['3.5'] = '(GMT +3.5 Hours) Tehran';
- $lang['tz']['4'] = '(GMT +4 Hours) Abu Dhabi, Muscat, Baku, Tbilisi';
- $lang['tz']['4.5'] = '(GMT +4.5 Hours) Kabul';
- $lang['tz']['5'] = '(GMT +5 Hours) Ekaterinburg, Islamabad, Karachi, Tashkent';
- $lang['tz']['5.5'] = '(GMT +5.5 Hours) Bombay, Calcutta, Madras, New Delhi';
- $lang['tz']['5.75'] = '(GMT +5.75 Hours) Kathmandu';
- $lang['tz']['6'] = '(GMT +6 Hours) Almaty, Dhaka, Colombo';
- $lang['tz']['6.5'] = '(GMT +6.5 Hours)';
- $lang['tz']['7'] = '(GMT +7 Hours) Bangkok, Hanoi, Jakarta';
- $lang['tz']['8'] = '(GMT +8 Hours) Beijing, Perth, Singapore, Hong Kong, Urumqi';
- $lang['tz']['9'] = '(GMT +9 Hours) Tokyo, Seoul, Osaka, Sapporo, Yakutsk';
- $lang['tz']['9.5'] = '(GMT +9.5 Hours) Adelaide, Darwin';
- $lang['tz']['10'] = '(GMT +10 Hours) EAST(East Australian Standard), Guam';
- $lang['tz']['11'] = '(GMT +11 Hours) Magadan, Solomon Islands, New Caledonia';
- $lang['tz']['12'] = '(GMT +12 Hours) Auckland, Fiji, Kamchatka, Marshall Island';
- $lang['tz']['13'] = '(GMT +13 Hours) Nuku'alofa';
#10 Sun 16 Dec, 2007 02:06 |
tiolalu
Mighty Gorgon, thanks again, I thinked in that, but... If I get to the well state I will have to change it again  , I will ask again to my host...
Thanks MG!
#11 Sun 16 Dec, 2007 02:10 |
tiolalu
Hi MG,
I have this asnwer after 10 emails, access to the server configuration and to the forum:
"We have checked the configurations and it looks like a problem with the forum since its not picking up the time zone from the server, Kindly contact a developer to check the files which picks the data settings from the server."
I don't think it's an error in the code because I've changed 5 times of server and in all it has been working well
#12 Tue 18 Dec, 2007 13:09 |
tiolalu
 Re: Solved - Change Time In The Forum
Mighty Gorgon, solved, the problem was the cache of the forum, I had deleted it and it was solved _ _U
#13 Sat 29 Dec, 2007 19:24 |
| Link this topic |
| URL |
| BBCode |
| HTML |
