Post Please Help With Flashchat Integration...
I installed flashchat on my main site and it works as promised except for Autologin. I figured out that it is because of phpBB XS not the flashchat script.
I did a test on my test server and installed both phpbb and flashchat and they both worked together very nicely including the Autologin for Flashchat. This leads me to be believe that when you guys put together phpBB XS you changed the login process which stops Flashchat from seeing that a user is logged into my site. I need to know how I might go about fixing this problem so that the Autologin works in Flashchat. Any help I could get would be most appreciated.
Thanks, Mr.Wizard
The Scripting Idiot!
Sua Sponte a World of Warcraft Tanaris Guild
MrWizardSend private messageVisit poster's website
Post Re: Please Help With Flashchat Integration...
Try asking the creator, add him to MSN, he's really helpful.
No site anymore
ClaireSend private message
Maybe this will help you.
In XS 0.40 it was working for me.
