Post .htaccess And File Download
hey!!!!
I need help!
I want make one directory to download and change the permison Similar to Dload to IP and not can“t xD
I make a directory in localhost and creat to .htaccess with this code
  1. <Limit GET POST PUT>
  2. Order Allow,Deny
  3. Deny from All
  4. </Limit>
But at the moment of putting a link of download it does not work
Code 403 forbidden xD
How can make a link to download similar to  IP?????????????????????????
www.dBoror.com [Danilo]
DaniloSend private messageVisit poster's website
Post Re: .htaccess And File Download
You have set this:
Deny from All
It deny all the connections.
Solution:
  2. Order Allow
  3. Allow from All
  4. </Limit>
Ensure to put a index file.
Thanks but dosent work xD
Maybe a satisfy from all tag...
I think if you have a .htaccess file in your root / parent directory it will override anything you specify in a .htaccess in a child directory... so if you have a .htaccess file with your "Deny from All" statement in your root folder, it will take precedence over anything in the sub directories... note "I think" - as far as I remember... been a while
Danilo, have you solved it?  if yes, can you tell me how, i am having the same issue right now.
Thank you,
xmenfileSend private message
