Post Black Pearl Style For Portal
Guys i dont know if i will be asking the right stuff... I am a newbie and i really like the Black Pearl Template So much, I am Wondering if there is a Black Pearl Style for Portal... and can i ask for it?
PS.
     Mighty Gorgon "You ROCK, you are the MAN!!!"
Thanks for your great WORK...
jingjong - View user's profileSend private message
Post Re: Black Pearl Style For Portal
I think you are using phpbb3 so topic is moving to "phpbb3 mods and styles"
Currently there is no template for Portal... but if you have subSilver 2 files it would be quite easy to adapt them to Black Pearl.
Can you make a test?
jingjong wrote: [View Post]
PS.
I concur what jing is asking. There are 3 portals out there right now for BB3 and all 3 are aweful. I want a portal created exactly like IMPortal or the IcyPhoenix Portal. No other portal as of now offers the benefits of IMPortal or IcyPhoenix Portal.
Ratt - View user's profileSend private message
Thank you for the appreciation, but at the moment there are no plans about the future...
First I need to release IP, then I will try to decide my priority list...
Fair enough, Guess we'll just have to wait for the best coded board there will ever be when you have the time to do it. Really nothing compares to your work. It's brilliant. Well I'm off to California to pick up a load of produce. See ya when I get the time to stop and rest.
I have tried to alter the style to work with Board3Portal, with the instructions for subsilver2.
How ever certain instruction it asks for are not located in the specified files.
Now I have seen that the build of this style is slightly different then subsilver2, so taking that approach and looking in the other files, like breadcrumbs and _index_body, how ever that kinda results into error like:
Parse error: syntax error, unexpected $end in /home/activeou/public_html/outlaws/cache/tpl_black_pearl_overall_header.html.php on line 187
Purged cache for style (templates) and for forum compleetly.
That didn't worked unfortunatly
So I must have been doing something wrong, kinda obvious, otherwise I'd would have worked.
That why I am wondering if there is another way arround to fix that error.
<!- edit -!>
Got it to work now, just needed to do a few things differently to make it work
sumthing - View user's profileSend private message
Do you have modified files for Black Pearl?
I think some users may find them useful if you share them.
Thank you.
I used the phpbb3 Portal for home in mine (I use Milky Way), installed the subsilver2 template files and works alright!
Here's a demo www.homeconcept.gr , if you need anything I'm here
I don't recall if I encountered any problems at all, I think I didn't (it's been two months since I installed it). Now I need some tweaks.
I could upload the portal folder for Milky Way if you want to and also, when I'm done with the Greek buttons, I'll upload them as well.
PS: Keep up the good work Mighty!
jpavly - View user's profileSend private message
Hello MG..
I've made some modification at the mkportal theme with any images of the black pearl..
This is the demo site
Furious Airbrush Team
Can you ( MG ) see if it's ok??
And ... Can I use this template with MK portal??
Thanks..
Bye Bye.. Marcius
marcius - View user's profileSend private message
jpavly wrote: [View Post]
Really great job,  many people be happy if you share your work..
Fanshop - View user's profileSend private messageVisit poster's website
Hi guys, where can I finde a portal for phpbb3.0.1?
and other thing...
how can I modify the header Logo...
I need something like this.
Filesize: 22.15 KB
Viewed: 33 Time(s)
mm33dd - View user's profileSend private message
mm33dd wrote: [View Post]
and other thing...
For the header logo, just replace the styles/milky_way/imageset/sitelogo_small.png file with yours.
For a portal, visit www.phpbb3portal.com and use the subSilver2 template. If you need anything else, just tell me. It should look like this -> www.homeconcept.gr after the installation.
I use Milky_Way but it should be the same for Black Pearl.
Yes... template files are almost identical.
Fanshop wrote: [View Post]
here you go
http://www.icyphoenix.com/viewtopic.php?f=32&t=4328
