Post Header Image Background
I have installed, set up my site up run good so far, but not in public yet.   I want o create a header image background , but could not do it right.  I am not good @ designing, it come out either small, stretch or too big.  I have searched here and Template & Style forum, but did not find what i am looking for.  Can anyone show me how to it?  BTW, I am using IP and MilkyWay.
Thank you so much,
xmen
xmenfileSend private message
Post Re: Header Image Background
I would be glad to help just let me know what you need.
Running two Icy forums on one server
Press 22Send private message
Thank you Press 22,
I have this pic and would like to know how to make it as header background.
Filename: magj93.jpg
Filesize: 53.3 KB
Downloaded: 108 Time(s)
do you want to resize that image for being a header?
Absolutely yes.   I don't want my header that big.  I am sorry abou that.
xmenfile wrote: [View Post]
What size do u want
I want it standard size for milky way.  but if you can tell me how it could be done?  I try to it my own, i appreciate it.
http://www.icyphoenix.com/files/images/15/header.jpg
970 * 150, milky header size
Zuker wrote: [View Post]
Thank you Zuker, i did not know it 's 970 in width.   I read it somewhere it's 730 or 1024 that's why i could not make it fit.
Thank you again, cheers
I think we have, had, the same problem.
I used the size dimensions mentioned by Zuker for my banner and it almost works.  I have attached a screenshot of my banner problem.
Every time I try to increase the length of my banner through Photoshop, it pushes the site to the right, leaving that gray line on the right.  If you look closely, you'll see the problem.  The height is perfect.  There has got to be something in the code that keeps pushing the site to the right when I add the banner.
I'm using the Black Pearl template, editing overall_header_bl, and running IP 1.1.10.25 RC3.
You can take a "live" look at the problem at http://www.thelocclan.com
Chaotic wrote: [View Post]
Your header it's right sized
I need some helps please.  I need to set it as background, replace the orange background. Look at what I did, it's not right.  Please let me know what file and how to fix it?
Thanks a bunch,
Solved
Thank you , cheers
Have any idea what could be causing the gray area on the right of the banner?  Here is my overall_header_bl.tpl file:
Well, it depends on how do you want to set it.  In you case, you set it as a logo like IP on this site, insteads your is bigger.  It looks fine if anyone view it in small screen, but it stretch out if it's bigger screen than your logo size.  Mine, i set it as a background, no link when you move mouseover.  If you do my way, then you'll need to edit it in the style_p_black.css file.  I hope, that helps.
good luck
good luck
Are you using Icy Phoenix 1.1.10.25 RC3?
I know this sounds stupid but where in the file (style_p_black.css) do I make the changes?  I think I have the general area narrowed down:
Is that the correct area and if it is, where do I make the change?
Thanks for your help.
