Post FAP On Other Template
I have tried to isntall FAP on another template but I am having no luck I have installed a test which i know works so i am installing it correctly but when i tried to install it on to another template i got the error below:
http://p1mp-productions.com/images/help%20help.JPG
Also I didnt do this part as it was related to the subsilver template:
#-----[ OPEN ]------------------------------------------------
templates/subSilver/simple_header.tpl
#-----[ FIND ]------------------------------------------------
@import url("templates/subSilver/formIE.css");
#-----[ REPLACE WITH ]----------------------------------------
/* @import url("templates/subSilver/formIE.css"); */
The simple header for the template that i have looks like this:
<!-- DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN"
    "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd" -->
<!-- <html xmlns="http://www.w3.org/1999/xhtml"> -->
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html dir="{S_CONTENT_DIRECTION}">
<head>
<meta http-equiv="Content-Type" content="text/html; charset={S_CONTENT_ENCODING}"  />
<meta http-equiv="Content-Style-Type" content="text/css" />
<style type="text/css">
</style>
{META}
<title>{SITENAME} :: {PAGE_TITLE}</title>
<link rel="stylesheet" href="templates/BF2/{T_HEAD_STYLESHEET}" type="text/css">
</head>
<body bgcolor="{T_BODY_BGCOLOR}" text="{T_BODY_TEXT}" link="{T_BODY_LINK}" vlink="{T_BODY_VLINK}">
<span class="gen"><a name="top"></a></span>
I need all the help I can get PLEASEEEEEEEE
P1MP_ChRiS - View user's profileSend private message
Post Re: FAP On Other Template
HELP ME SOME ONE PLEASEEEEEE
ARTIEEEEE!
The error is not related to template modifications. It's impossible.
Have you runned fap_install.php?
Greets!
Gabriel Anca
KasLimon - View user's profileSend private messageVisit poster's website
No I manually installed each SQL table just the same as i did before!
I dont really understand how to run the faq_install
Just test it. Upload the file to the root of your Icy Phoenix and run it (http://www.yourweb.com/fap_install.php)
It should return a lot of errors, but it doesn't mutter. It should repair it...
Please, test, delete the file and tell me if it's solved. Greets!
Gabriel Anca
Ah ha thats how you do it LOL works good now thanks alot
Yes, I think the problem was you forgave to do some queries.
Nice to know it works. Greets!
Gabriel Anca
