Page 1 of 3
Goto page 1, 2, 3  Next
Post Sudoku MOD 2.5.2
What are the differences between this and the including version in IP?
There are a few differences between this MOD and the one that is included into IP. The most important is the three kinds of Sudoku and the addon Full leaderboard for the competition between the users.
The following kinds of Sudoku comes with this MOD
Sudoku
sudoku1
Sudoku Samurai
sudoku2
Sudoku Ninja
 sudoku3
How can I install this package?
It's really easy, upload the whole content of this package to your ip_root and execute the including db_update.php. After this delete db_update.php from your ip_root and clear your template cache and enable the board sudoku in the ACP.
Make sure that you have installed the release of 03032007 and that you have not modded the included files but else it should not work.
Where can I download this package?
You can download this package with the next link
IP Sudoku 2.5.2
Package Name: IP Sudoku
Package Version: 2.5.2
Release Spot: More sudoku with IP!
DOWNLOAD: IP Sudoku 2.5.2
If you have found problems or you need support? Ask it in this topic!
Edited by brandsrus, Thu 13 Mar, 2008 23:09: New package uploaded (version 2); folder images added
Post Re: Sudoku MOD 2.5.2
Great job Brandsrus!
I do have small request of sorts.  Is it possible to change the colors of the starting numbers on the grid?  I ask this because I use the Black Pearl template and the grey outlined numbers are too small and too hard to see with the black background.
Here is a screenshot of the problem:
You can also test this mod out on my website: http://www.thelocclan.com/phpBB2/sudoku.php
Username: test
Password: 1234
You can use the attached .zip (Colors on white background)
Copy the folder to b_pearl and in the mg_themes.cfg change the Sudoku config to:
Or just use them to overwrite the existing images in common/images/sudoku
sudoku.zip
Filename: sudoku.zip
Filesize: 8.52 KB
Downloaded: 415 Time(s)
Lopalong, thanks for replying.  I've downloaded the file and put it in my templates/common/images/sudoku.  I've also made the code change in templates/mg_themes/mg_themes.cfg.  I've made all the changes you said but I still don't see a change in the number colors.  I have to be something wrong?
Can you include the Spanish language please?
URL: http://agressor.cl
Versi?n: Icy Phoenix 1.2.0.27
Plantilla usuada: Black Pearl
MODs instalados: Level Mod
Parches Instalados: Nothing
Servidor: http://dreamhost.com
HazardSend private messageVisit poster's website
@ Chaotic,
You only needed to use the code if you put the Sudoku folder in the p_black folder. So just revert the code to the original. You will also need to clear the template Cache in the ACP.
Hazard wrote: [View Post]
Sorry, i can't speak or write spanish, maybe anyone else can make this for this MOD
Lopalong, thanks for your support here in this topic, I really appreciated it!
Lopalong wrote: [View Post]
@ Chaotic,
For some reason, that still didn't do the trick.  I was looking at the images in the folder you provided and they look the same.  They are black numbers.  I need something more like white numbers for the dark background I have.
They don't have a transparent background they are white tiles with black and orange numbers. Most viewers show the transparency as white or off-white, so they would look roughly the same.
If you want white numbers on a transparent background and you can't do them yourself, I'll do them for you. But! if you also have "Light" themes available for your users, you will run into the same problem there; they wont be able to see them.
This is what those tiles should look like.
Filesize: 12.96 KB
Viewed: 18951 Time(s)
I got it working.  Thanks for your help Lopalong!
You're welcome.
The code above is useful if you want to have different coloured tiles for different themes. It also means of course that all themes would have to have a Sudoku folder added to "their" color-folder. Example: p_black/sudoku
You're welcome.
This images works in Samurai and Ninja???
It seems that it only works for the standard sudoku, not samurai or ninja.  At least that's what I see on my website.
Any language changes since last version?
I've translated old version ACP to spanish
And I'll translate main language ASAP
Greets!
Gabriel Anca
KasLimonSend private messageVisit poster's website
KasLimon wrote: [View Post]
Greets!
Can you PM me your files, than can i check if all is ok. Thanks in advance!
