Post 1.2.0.27 With Phpbb3
Hi i see thtat 1.2.0.27 is baseod on  phpbb 2.0.23 can i update ir to phpbb3?, how?
Nycoh - View user's profileSend private message
Post Re: 1.2.0.27 With Phpbb3
You will have to downgrade to plain phpbb2 first. I don“t recommend that as you lose all data that phpbb2 does not use during the downgrade (IP-phpbb2).
~~ novice programmer ~~
novice programmer - View user's profileSend private messageView user's personal gallery
Nycoh wrote: [View Post]
You can't update phpBB2.0.23 "inside" IP 1.2.0.27 to phpBB3.x.x!!
IP is based on phpBB2 and it will not ported on phpBB3, so if you want to use phpBB3 you don't need IP...
~~~ Andrea ~~~
User #379756 on Linux Counter
buldo - View user's profileSend private messageVisit poster's website
