 Icy Phoenix 1.2.0.27b Patch
Hi all,
here is a patch for Icy Phoenix 1.2.0.27 to fix some reported bugs.
All you have to do, in order to apply this patch, is to replace all files in your Icy Phoenix 1.2.0.27.
No DB and no TEMPLATE changes...
This patch will raise your versions to 1.2.0.27b from any 1.2.0.27 version you have installed.
You are invited to update your sites ASAP.
Icy Phoenix 1.2.0.27b Patch Package Name: Icy Phoenix Patch
Package Version: 1.2.0.27b (it is a cumulative patch since 1.2.0.27)
Release Spot: Optimizing Memory...
DOWNLOAD: Icy Phoenix 1.2.0.27b Patch
Only changed files since Patch A: http://www.icyphoenix.com/_release/ip_20080426_12027_patch.zip
P.S.: if you downloaded full package after 2008/04/26 you don't need to apply this patch.
#1 Sat 26 Apr, 2008 22:43 |
Thanks for the useful Topic Mighty Gorgon: JANU1535 (26 April), xmenfile (26 April), Lopalong (26 April), ThE KuKa (26 April), BEN-HUR (26 April), Corleone (27 April), m740 (27 April), paramine-gx (27 April), Limun (27 April), JHOSMAN (27 April), invi (27 April), Harimau (01 May), pavan4ufriend (23 June) |
Zuker
 Re: Icy Phoenix 1.2.0.27b Patch
Downloading and testing
#3 Sun 27 Apr, 2008 02:18 |
Zuker
There are three = on this line (739) of functions.php, it's right?
- elseif ( ($userdata['user_id'] === ANONYMOUS) && ($board_config['default_lang'] !== $default_lang) )
#4 Sun 27 Apr, 2008 02:34 |
KugeLSichA
thanks... downloading and install...
#5 Sun 27 Apr, 2008 12:18 |
tc1967uk
A special thanks for including the section about 'Only changed files since Patch A'. It made updating my site so much easier, as I only had to amend 1 file and I could upload and overwrite the rest.
#6 Sun 27 Apr, 2008 17:02 |
JHOSMAN
____________ ? JHOSMAN - Webmaster
#7 Sun 27 Apr, 2008 23:20 |
Hazard
Very thx
Second page in Album works!!!
____________ URL: http://agressor.cl
Versi?n: Icy Phoenix 1.2.0.27
Plantilla usuada: Black Pearl
MODs instalados: Level Mod
Parches Instalados: Nothing
Servidor: http://dreamhost.com
#8 Mon 28 Apr, 2008 00:16 |
Zuker
JHOSMAN, you 'll have to ask the author of that mods.
#9 Mon 28 Apr, 2008 12:30 |
KasLimon
Thanks for the new patch!
It shouldn't...
I think this should be right:
- elseif ( ($userdata['user_id'] == ANONYMOUS) && ($board_config['default_lang'] != $default_lang) )
But you never know, maybe it is a special reason for doing it that way...
Greets!
____________ Gabriel Anca
#10 Wed 30 Apr, 2008 15:40 |
KasLimon
Ok, sorry
#12 Wed 30 Apr, 2008 16:37 |
Zuker
JHOSMAN, you need to edit your constants.php again I guess...
Zuker and KasLimon, please refer to PHP manual to learn how comparisons may be made...
http://php.net/manual/en/language.operators.comparison.php
=== is different from == and needs to remain as is.
that's why i asked
#13 Wed 30 Apr, 2008 22:19 |
Thanks a lot. download and install
#14 Fri 02 May, 2008 18:15 |
Morlock
I have overwritten all the files and my header has disappeared. You can check here:
http://fisioweb.org
I have no image nor navigation var (Log in, search, unread messages...).
I have tried to reupload again the files, clean cache... But doesn't work. Any help?
Thank you in advance.
#15 Mon 12 May, 2008 16:48 |
| Link this topic |
| URL |
| BBCode |
| HTML |
