portalpez
 SOLVED - Phpbb3 Template For Icy Phoenix, Is Posible?
Hello,
I like very much Icyphoenix, but the templates of icyphoenix is hard to charge in internet explorer due to a lot of images.... The templates of phpbb3 is very soft to charge.
Anyone is thinking in make a template based on phpbb3 for icyphoenix? It will be very usefull.
I try to do a soft template, but is very dificult for me, because i am not a designer.
Is there any other template for Icyphoenis more soft?
Thanks very much.
Sorry about my english.
#1 Wed 11 Jun, 2008 22:27 |
Inactive User
 Re: Phpbb3 Template For Icy Phoenix, Is Posible?
Try this - Using Search and Replace.
Open the style_*.css that you are using.
Find: .gif
Replace ALL with: XXXX
Now find: .roundedhc and .roundedfc and change the XXXX back to .gif
From there you can examine all of the XXXX and decide if you want to put them back (One at a time) or simply remove the url('s and change or add #color to the strings.
#2 Thu 12 Jun, 2008 00:26 |
portalpez
Thanks you Lopalong,
I try to do this... and i show you the resuls.
#3 Thu 12 Jun, 2008 00:31 |
Inactive User
You're welcome,
To add or change the category colours find (in the modded .css): bg_thXXXXX
Change the "#color" in the strings to compliment the headers. And I'm looking forward to see what results you come up with.
#4 Thu 12 Jun, 2008 01:00 |
portalpez
Twomorrow i upload other template to experiment, but now i go to the bed... thanks you.
I try to create a very soft template... ugly but soft.
#5 Thu 12 Jun, 2008 01:10 |
portalpez
Hello,
I do it. Go to http://www.portalpez.com/foroportalpez/index.php and select in style box the theme mg_soft.
Say me if run more fast than the normal style... thanks you for your help.
#6 Thu 12 Jun, 2008 13:09 |
Inactive User
Nice fix, it's certainly quicker than the normal Icy Theme.
#7 Thu 12 Jun, 2008 13:24 |
portalpez
 Re: SOLVED - Phpbb3 Template For Icy Phoenix, Is Posible?
Thanks you Lopalong!!
It is a litle ugly the theme to compare whith a normal them...but i am not a designer.
#8 Thu 12 Jun, 2008 13:34 |
Inactive User
Blues are always difficult to work with because the other colours either have to blend in, or be in total contrast with the main colour.
If you need to know what colours are what and what to change them to by example - then download and install this, as it's a very useful tool.
h**p://***.eltima.com/products/free-color-picker/
#9 Thu 12 Jun, 2008 14:10 |
portalpez
Downloading...
#10 Thu 12 Jun, 2008 14:31 |
Inactive User
Now you will be able to pick the colours from any website that you would like to change your theme to, or from any pictures etc, once you learn how to use it.
For example:
Your main theme colours are:
7D7BFF, 7CBFFF and E1EEFC
So if i wanted to use your colours - I've already got them
#11 Thu 12 Jun, 2008 14:56 |
portalpez
Ok, even though my theme is far to look like phpbb3 theme, It is good now I suposse and I thinks i will not change anything else.
Thanks you.
#12 Thu 12 Jun, 2008 15:08 |
