Post Mini-Calendar Block Problem
I have problems because the calendar links are searching post and not the event.
Next I found the answer that hoew to change it the POST for EVENTS.
http://www.icyphoenix.com/viewtopic...+calendar+block
Next I clear the Cache... but now the Calendar is empty, no have links and if you see into the calendar
http://en2ruedas.byethost5.com/calendar.php
I have two events (3th and 7th august).
I search into the forum and found this another post, but is for older version that i have installed:
Thanks for any help.
DP: Sorry my english is not very good.
Tech Information:
PHPBB Version: 1.2.0.27
Web: http://en2ruedas.byethost5.com
Forum: http://en2ruedas.byethost5.com/forum.php
Server: Free without Ad
Plantilla Actual: Morpheus Green (Change it to Red Red with ColorizeIt)
OS: Windows XP
Host Operate System: Linux
MODs Installed: No
equiman - View user's profileSend private message
