Post 2 Minor Thingies..
hope that they count
screenay02wk8.th
screenay01wu6.th
missing "Link-to-Us" button
and the "Show Calendar" doesn't show
using Aphrote Text if it matters..
check out my site sometime
www.Dutch-HQ.net
NizzleSend private messageVisit poster's website
Post Re: 2 Minor Thingies..
I'm sorry...
I think that's caused by Opera... at least the second one.
Megabass
ganeshSend private messageVisit poster's website
it shouldn't be
always worked with other releases..
www.Dutch-HQ.net
Well... in my test board does work both in FF and IE... and I also tried it with Safari and Konqueror yesterday.
I repeat 'cause I was wrong before...
Megabass
hmm just checked with FF and the calendar works..
not the link button thingy though
and with the MG style there ain't no calendar with either FF or Opera
www.Dutch-HQ.net
Link Us button is working for me with FF and IE... and I don't have any other browser to test this.
Show Calendar is not presente in MG Themes, because I don't like that function!
Hi all, i'm Gomesh.
Well: i've found 2 probables bugs:
1) If you set a message in Server & Cookies for Disabled Board, and Update, message is present and visible. But if you set other tricks in Various Settings, and update it, the message in Server & Cookies will be erase (Probable sql update in Various Settings modify this value);
2) In "Viewonline" status i see many people in Index Album and some topic link is wrong, because i click on this link, back on forum section of this topic and i not see the user in this section.
P.S. Sorry for me incomprensible English
cYa All.
In Memory of mrTrade
La maturit? della gente si evince da quel dice, non da quello che racconta.
GomeshSend private message
Gomesh wrote: [View Post]
Hi all, i'm Gomesh.
cYa All.
Thanks Gomesh for reporting.
The first bug has been already fixed in the dev release.
The second is due to sessions refresh... remembers that sessions are refreshed every 300 seconds (five minutes)... so they could be not updated. You can decrease the refresh time by editing sessions.php, but then you should charge your server with additional SQL...
Ti rispondo al volo in Italiano: avevo pensato fosse un problema di timelimit, ma i lproblema reale è questo: il link al topic riporta giustamente Forum (Sezione) >> Titolo del Topic (Link).
Praticamente la sezione è giusta mentre il Link è errato. Sono andato a vedere la tabella relativa e, praticamente, viene assegnato al topic_session un valore uguale al numero di user_id dell'utente.
Quindi: se clikko direttamente su quel link mi porta al messaggio corrispondente all'user_id dell'utente che in quel momento lo sta visualizzando. Se da quella posizione clicco sul Forum (La sezione, per intenderci) l'untente non è presente. Allora per vedere realmente dove sta l'utente devo andare nuovamente su Viewonline e, invece di cliccare sul titolo del messaggio che l'utente sta visualizzando devo cliccare, invece, sul Forum. In questo modo trovo l'utente presente in quel Forum. Ho provato a togliere il tuo Add-on relativo al session_topic (Per intenderci la semplice visualizzazione classica di phpbb che ti dice la sezione dove si trova l'utente) e funziona.
In first time i've change this limit of time refresh for SQL, but the problem is the same. The link visible in Viewonline in Forum >> Title of Topic (Link). Well: the Section of Forum is correct, but the title is wrong. I've see the relative table of SQL and i've see one inconsistence (Probable in my SQL's Tables): the session_topic value report the same number of user_id who see the topic.
cYa All.
Others minor Bugs:
1) When you click on [View Message] in a Quote or in #number of reply (Vbulletin tipe, bottom avatar), if the author have a gif or jpeg signature, this's wrote in [_img_]http://www.address_image.xxx[_/img_] (Without Underscore) and isn't visible;
2) When u quote > quote > quote > quote message, the latest quote is reported in [quote=message . . . ] and isn't really quoted. Es.:
[quote user="Gomesh" post="10831"]
1st Quote
[/quote]
2nd Quote
3th Quote
4th Quote
P.S. Per la versione BetaTester bastano questi Bugs
I think that the #1 was reported at xs.com weeks ago
www.LphantES.com
zankywSend private messageVisit poster's website
Yes, it was...
Megabass
I'll check this again... Thanks.
It's not a bug... the bug was in viewtopic... because IMG should be disabled in signatures by default...
Anyway this should have been fixed in 058.
It's not a bug... you have an option in ACP for limiting nested quotes.
Gomesh, viewonline section is working fine here... just tested!
you should just make that html valid at least it'll work with alot more browsers then
or at least it should work then..
yeah me neither
can't you just disable that in the ACP or something?
www.Dutch-HQ.net
