Post Beware Of Google Chrome - It's A SPY!
Many thanks to Zottle for this snippet.
Though I cannot vouch for the accuracy of the report; or the SECURITY or effectiveness of the fix, I thought I'd pass it on.
"Google Chrome is a browser that combines a minimal design with sophisticated technology to make the web faster, safer, and easier". Unfortunately, each Google Chrome installation contains a unique ID that allowing identifying its user. Google doesn't make it an easy job to remove this ID. UnChrome helps you with this task. It replaces your unique ID with Null values so that your browser cannot be identified any longer. The functions of Google Chrome is not influenced by this. You only need to apply UnChrome once. If Google Chrome is started now then please close it. Afterward, please click on the link below to anonymize your Chrome installation.
h**p://***.abelssoft.net/unchrome.php
