Post PHP Based Code To HTML With BBcode
]I wrote this PHP script to convert JAVA, PYTHON, VISUAL BASIC, and VISUAL BASIC .NET to formated html, using a style sheet.
i.e.
  1. // Sample Class provide to demostrate how to create Abritute methods in Java
  2. public class Sample1
  3. {
  4.     // internal variables
  5.     private int age;
  6.     // Asscesor or Get Method
  7.     public int getAge()
  8.     {
  9.         return age;
  10.     }
  11.     // Mutator or Set Method
  12.     public void setAge(int value)
  13.     {
  14.         age = value;
  15.     }
is converted to
  1. <span class="Comment">// Sample Class provide to demostrate how to create Abritute methods in Java</span><br>
  2. <span class="Keywords">public</span> <span class="Keywords">class</span> Sample1<br>
  3. {<br>
  4.     <span class="Comment">// internal variables</span><br>
  5.     <span class="Keywords">private</span> <span class="Keywords">int</span> age<span class="Operator">;</span><br>
  6.     <span class="Comment">// Asscesor or Get Method</span><br>
  7.     <span class="Keywords">public</span> <span class="Keywords">int</span> getAge<span class="Operator">(</span><span class="Operator">)</span><br>
  8.     {<br>
  9.         <span class="Keywords">return</span> age<span class="Operator">;</span><br>
  10.     }<br>
  11.     <span class="Comment">// Mutator or Set Method</span><br>
  12.     <span class="Keywords">public</span> <span class="Keywords">void</span> setAge<span class="Operator">(</span><span class="Keywords">int</span> value<span class="Operator">)</span><br>
  13.     {<br>
  14.         age <span class="Operator">=</span> value<span class="Operator">;</span><br>
  15.     }<br>
  16. }<br>
see this page for the output to user http://learntoprogram.net84.net/ind...itute&lang=java
I want to adapt this script so that it works with both, IcyPhoenix and phpBB3 BBcode for the [Code] tag.
Can someone give me some help with this, Thank you.
Also feel free to use this code your self, under the trems of either the CDDL or GPL
Also the code takes both a string for the code input or a filename that points to a source file, it also takes a language ID.
phpcode2html.tar.gz
Description: This is an archive of the code with all every thing I've done with it as of Sat 20 Sep 2008 11:31:31 EST.
Filename: phpcode2html.tar.gz
Filesize: 2.97 KB
Downloaded: 257 Time(s)
glenfletSend private messageVisit poster's website
Post Re: PHP Based Code To HTML With BBcode
Moved to "Other Mods Support" - - -
I worked out how to do this with pbpBB3 BBcode, but I'm not sure how to do it with Icy Phoenix, can some one help m
EDIT: Tue 23 Sep, 2008 23:39
I found out My so called succes was not what it seams, the varable passing didn't work proply, it only worked because my test language was the defualt language.
So i need halp with passing, singal variable to phpBB3 BBcode, I aslo need to known how if possible to pass mulitable variables in phpBB3.
to be able to use these scripts within Icy Phoenix you need to alter bbcode.php and add highlighting there.
You can refer to CODE part in that file and apply what you need.
Regarding phpBB 3... I don't know.
It may also be helpful if you add your attachments in .zip format only - Not everyone uses exotic compression.
I Include the followign file in the BBcode.php
<?php
  * @package PHPCode2Html
  * @version 1.0
  * @copyright (c) 2008 Glen Fletcher
  * @license DUAL LICENSE CDDL+GPL (http://www.opensource.org/licenses/cddl1.php, Common Development and Distribution License (CDDL)) & (http://opensource.org/licenses/GPL-license.php GNU Public License)
include("phpjava2html.php");
include(
"phppython2html.php");
include(
"phpvb2html.php");
include(
"phpvb_net2html.php");
  * Main Function
  * @param $filename - The Filename of the source file
  * @param $lang - The Language of the source file, string = "JAVA", "PYTHON", "VB", or "VB.NET" assumes JAVA
  * @return The Content of the source file in html format.
function source2html($filename, $lang = "JAVA")
$line = "";
    if (
file_exists($filename))
$file = fopen($filename, "r");
        while (!
feof($file))
$line = fgets($file,4096);
$lines = $lines . $line;
fclose($file);
$lines = code2html($lines, $lang);
    return
$lines;
  * Code Converter
  * @param $lines - The Source Code
function code2html($lines, $lang = "JAVA")
$lines = ereg_replace("&lt;", "<", $lines);
$lines = ereg_replace("&gt;", ">", $lines);
    switch (
$lang)
        case
"JAVA":
$lines = java2html($lines);
            break;
        case
"PYTHON":
$lines = python2html($lines);
            break;
        case
"VB":
$lines = vb2html($lines);
            break;
        case
"VB.NET":
$lines = vb_net2html($lines);
            break;
        default:
// Assume Java, if fail
            break;
    return
$lines;
I put the following in the syntax = php if statment
else
    $text = code2html($text,strtoupper($item['params']['syntax']));
However when I tested it with lang = python, I get a blank code box, wwhy would this happen
I got the following HTML Output
div class="code"><div class="code-header" id="codehdr2_2789d6ba" style="position: relative;">Code: [<a href="javascript:void(0)" onclick="ShowHide('code_2789d6ba','code2_2789d6ba',''); ShowHide('codehdr_2789d6ba', 'codehdr2_2789d6ba', '')">Hide</a>]</div><div class="code-header" id="codehdr_2789d6ba" style="position: relative; display: none;">Code: [<a href="javascript:void(0)" onclick="ShowHide('code_2789d6ba','code2_2789d6ba','');ShowHide('codehdr_2789d6ba','codehdr2_2789d6ba','')">Show</a>]</div><div class="code-content" id="code_2789d6ba" style="position: relative;"><ol class="code-list" start="1"></ol></div></div>
from
[code linenumbers=true syntax=python]def Hello():
    return "Hello World"[/code]
Try to add your code here:
                $php_syntax = false;
                if(isset($item['params']['syntax']))
                    if ($item['params']['syntax'] == 'php')
                        $html = strtr($text, array_flip(get_html_translation_table(HTML_ENTITIES)));
                        $html = highlight_string($html, true);
                        $html_search = array('<code>', '</code>', '<font color="', '</font', '&nbsp;', '<code style="color:#0000BB"></code>', '<code style="color:#0000BB"> </code>');
                        $xhtml_replace = array('', '', '<code style="color:', '</code', ' ', '', '');
                        $html = str_replace ($html_search, $xhtml_replace, $html);
                        $php_syntax = true;
Add an elseif statement to check the syntax you want to apply, and then just apply the function to $html var.
Remember that we are in linenumbers = false now... but first try to apply the code there just to check if it works, then we will try to extend it to other parts.
Ok I've got every thing working now, thanks for the help.
How to Install this BBcode
EXTRACT phpcode2html.zip to includes/phpcode2html/
COPY code.css to templates/mg_themes/
OPEN includes/BBcode.php
global $db, $board_config, $phpbb_root_path, $phpEx, $lang;
ADD AFTER
include($phpbb_root_path . 'includes/phpcode2html/phpcode2html.'. $phpEx);
                        $html_search = array('<font color="', '</font', '&nbsp;', '<code style="color:#0000BB"></code>', '<code style="color:#0000BB"> </code>', '>  <');
                        $xhtml_replace = array('<code style="color:', '</code', ' ', '', '', '>&nbsp;<');
                        $html = str_replace($html_search, $xhtml_replace, $html);
                        //PHP Highlight - End
ADD AFTER
                    else
                        $text = html_entity_decode($text);
                        $text = ereg_replace(html_entity_decode("&nbsp;")," ",$text);
                        //Add Span based Code highlighting using style sheets
                        $html = code2html($text,strtoupper($item['params']['syntax']));
                        $html = ereg_replace("<br />n", "&nbsp;</span></li>n<li class="code-row"><span class="code-row-text">",$html);
                        $html = "<li class="code-row"><span class="code-row-text">" . $html;
                        $php_syntax = true;
ADD AFTER
                    else
                        $code_syntax = true;
FIND ALL
$php_syntax
$code_syntax
OPEN templates/mg_themes/
@import url("dock.css");
ADD AFTER
@import url("code.css");
NOTE You need to repeat this step for any other installed styles, Also, if you have other style directory's code.css should be copyed to them as well
code.css.zip
Description: Code highlighting style sheet
Filename: code.css.zip
Filesize: 260 Bytes
Downloaded: 225 Time(s)
phpcode2html.zip
Description: Special Version of phpcode2html designed for use with BBcode there are a few necessary changes to my original code
Filename: phpcode2html.zip
Filesize: 7.2 KB
Downloaded: 229 Time(s)
That's nice, thanks for sharing.
I will move this to Icy Phoenix Customizations.
Thanks for this mod.  I have installed and get this message
I looked at my bbcode. php and it's this line and not sure this a typo or not.
Let me know,
Thank you,
xmenfile
xmenfileSend private message
Sorry that was a small error on my part
I losted the escape charaters when I copyied the code into the post.
change
to
also change your next line to the following it will be incorret as well
I've Recently Made Several improvements to PHP Code 2 Html, so if your useing it you may want to update to this version it has no known errors.
phpcode2html.zip
Description: PHP Code 2 Html Ver. 1.2
Filesize: 7.23 KB
Downloaded: 192 Time(s)
Thanks for sharing, I'm sure CODING dedicated forums will appreciate this.
Good job.
