Post Colors And Groups
If a user is member of more than one group, and every group has its own color, how will the user's nick be coloured?
Edited by Guest, Wed 01 Oct, 2008 00:15: Edit title
Post Re: Quick Question About Colors And Groups
well , one question with multiple answers
1. user will be colored from last known usergroup
2. user will be colored from last known color
3. if you colorize all members in "some" group , and this member is member of this group , he will take "some" color
4. you can only select this member in group "zzz", and colorize only him with color of group "zzz"  , but if you do again step 3. (if member is also in group "some") member will take again color from group "some"
So, basically, every user takes the color of the last "refreshing" (or assignement) to his own color or to the color of one of the groups he is part of.
Example:
A user is part of the groups A, B and C. If the last group I put him in is B he will be displayed as User. But if I, later on, change the group C to C, he will be then displayed as User.
(still being member of all the 3 groups)
Am I right?
Vortex wrote: [View Post]
Am I right?
yes he will be member of all 3 groups not important if you change member color
yes
yes ,only if you "colorize all members" in new one C
sec , i will show you a pic
 groups
This is amazing. Thanks a lot for your kind patience, Limun ^_^
(I would suggest your explanation to be in the docs section)
