Post Problem Changing Web Description Results On Google
I want to change the description result on google for my website. On google it show's this:
"Icy Phoenix is an highly customizable CMS based on phpBB which allows you to create a dynamic site with a lot of features for powering web communities. -"
My web url is this www.mijos-powaaa.es
How I do this change?
Thanks for all!
tonifres - View user's profileSend private message
Post Re: Problem Changing Web Description Results On Google
Open: ip_root/YourLanguage/lang_XXX/lang_main_settings.php
Look for this line: $lang['Default_META_Description']
Hope that helps!
Chaotic - View user's profileSend private messageVisit poster's websitePersonal Gallery
Ok, thank you. I'll try it.
Let us know if that worked for you! (It will, but just for completion purposes!)
I changed it, but at the moment google it's showing the same. I think it take a while for change on google database.
True.  True.
Glad we could help!
Post Re: SOLVED - Problem Changing Web Description Results On Google
It works fine, thank you!
Sounds great!  Thanks for letting us know.
