Post Fatal error: Allowed memory size
Hello:
Fatal error: Allowed memory size of 8388608 bytes exhausted (tried to allocate 184320 bytes) in /home/s02ff9a6/public_html/cache/tpl_ca_aphrodite.layout.3_column.php on line 223
Some solution. Thanks. http://www.foroxerbar.com/
MorphSend private messageVisit poster's website
Post Respuesta: Fatal error: Allowed memory size
Solved : .htaccess to put this line    php_value memory_limit "16M"
Post Re: Respuesta: Fatal error: Allowed memory size
Morph wrote: [View Post]
0050 thanks.
*VOLVO CLUB*
Post Re: Fatal error: Allowed memory size
Great... I'll add this in Docs section.
Thank you!
Mighty Gorgon, OK
Post Re: Respuesta: Fatal Error: Allowed Memory Size
Sorry,
If I put this line in .htaccess I get:
Internal Server Error
The server encountered an internal error or misconfiguration and was unable to complete your request.
How can solve this?
Bags!!!
bagsSend private message
bags,     that error has before.
I feel it translated with translator
Post Re: Fatal Error: Allowed Memory Size
Sorry I dont' understand you fully.
What I mean is:
 - I've modified .htaccess adding php_value memory_limit "16M"
 - refreshing my site I obtain the error I wtote before.
Actually I've removed that line from .htaccess and I get always the same memory error error trying to rebuild search indexes
Bags!!!
bags, some servers doesn't support that htacces modification. The only way to change this value is asking them to do it
Zuker wrote: [View Post]
AAARRRGGGHHHH
I'm in hosting from Aruba
I don't think they'll do this to me
Bags!!!
Zuker, Ok thanks for the explanation
bags wrote: [View Post]
AAARRRGGGHHHH
Bags!!!
You can add the code in the PHP...
For example you can try this: http://www.phpbbxs.eu/viewtopic.php?p=1528#p1528
Tnx Mighty,
now it works good.
Bags!!!
Caro Mighty Gordon,
seguo da tempo tutti i tuoi consigli e posso definirmi un tuo fan.
Ho un problema che mi sta facendo impazzire.
Ho un forum phpbbplus, ed una categoria dello stesso è aperta agli utenti anonimi.
Ahimè, da un pò di tempo, quando voglio visualizzare l'indirizzo ip dell'utente anonimo che ha postato un topic,
ricevo questo messaggio
Fatal error: Allowed memory size of 12582912 bytes exhausted (tried to allocate 35 bytes) in /web/htdocs/.../.../includes/functions.php on line 804
Sono su un hosting Aruba.
Ho provato le cose consigliate in questo e nell'altro messaggio, ma non sono riuscito.
C'è una soluzione, o un perchè?
Cordiali saluti, Vincenzo
travagghioSend private message
travagghio, scusa, ma questo è un forum di supporto in inglese e riguardante phpBB XS... tu fai una richiesta in italiano e per Plus... Sarai d'accordo che c'è qualcosa che non va...
Per favore, fai questa richiesta nel forum apposito sul mio sito o sul supporto italiano di Plus.
In ogni caso, non so da cosa possa dipendere... teoricamente è un problema di memoria risolvibile aumentando il limite di memoria... comunque ne parliamo in altra sede.
English: support question moved to italian support...
