Post Phpbb 3 Portal And Black Pearl Style
Hi
I need help for edit 3 files I do not obtain to find the code lines in
Files to Edit
styles/subsilver2/template/overall_header.html,
styles/subsilver2/template/breadcrumbs.html,
styles/subsilver2/template/overall_footer.html
I do not find the lines
Open: styles/subsilver2/template/overall_header.html
Find
Tip: This may be a partial find and not the whole line.
Code:Select All
    <div id="menubar">
Add before
Tip: Add these lines on a new blank line before the preceding line(s) to find.
Code:Select All
    <!-- IF not $S_IN_PORTAL -->
Find
Code:Select All
    <!-- INCLUDE breadcrumbs.html -->
    <br />
Add after
Tip: Add these lines on a new blank line after the preceding line(s) to find.
Code:Select All
    <!-- ENDIF -->
Open: styles/subsilver2/template/breadcrumbs.html
Find
Code:Select All
            <p class="breadcrumbs"><a href="{U_INDEX}">{L_INDEX}</a>
Replace With
Tip: Replace the preceding line(s) to find with the following lines.
Code:Select All
            <p class="breadcrumbs"><a href="{U_PORTAL}">{L_PORTAL}</a> » <a href="{U_INDEX}">{L_INDEX}</a>
Open: styles/subsilver2/template/overall_footer.html
Find
Code:Select All
    <!-- IF TRANSLATION_INFO --><br />{TRANSLATION_INFO}<!-- ENDIF -->
Add after
Code:Select All
    <!-- IF S_PORTAL_COPY --><br />{S_PORTAL_COPY}<!-- ENDIF -->
It does not exist these lines
my English is horrible
SneikiSend private message
Post Re: Phpbb 3 Portal And Black Pearl Style
you need to find :
in styles/subsilver2/template/overall_header.html
find this
<div id="menubar">
and add before this
pics demo
 find5
 find6
find (in my case this is last line)
    <br />
affter add
<!-- ENDIF -->
pic sample
 affter_add
in styles/subsilver2/template/breadcrumbs.html
find this
replace with this
<p class="breadcrumbs"><a href="{U_PORTAL}">{L_PORTAL}</a> ยป <a href="{U_INDEX}">{L_INDEX}</a>
pisc demo
 find1
 find2
in styles/subsilver2/template/overall_footer.html
find
affter add
pics demo
 find3
 find4
Sorry i dont find lines in my
styles/black_pearl/template/overhall_header.html
styles/black_pearl/template/overhall_footer.html
styles/black_pearl/template/breadcumbs.html
this is my portal
***.88id.com.br/forum/portal.php
In  styles/subsilver2/template I find all lines but in the archives of the black pearl in styles/black_pearl/template not
Sneiki wrote: [View Post]
Hi
Files to Edit
ok ok , i will try to find those lines in black pearl
i supose u are trying to install portal from here http://www.icyphoenix.com/viewtopic.php?f=32&t=4328
right ?
EDIT
ok... i created it
so download my attachment extract it...
you will see inside 3 files : overall_footer.html , overall_header.html and menu_block.html
upload it in your stylesblack_pearltemplate....
thats all
PS.  menu_block.html you dont need to upload but if you want to see "Portal" in navigation what i added it , than upload it (see pic what i mean)
 portalblack
backup your overall_footer.html , overall_header.html and menu_block.html before you upload mine
enyoj
template.rar
Description: overall_footer.html , overall_header.html and menu_block.html for black pearl style
Filename: template.rar
Filesize: 3.49 KB
Downloaded: 321 Time(s)
ok Limun
I made upload of the archives and link portal in my forum is ok
But my portal the blocks continue disaligned
See - ***.88id.com.br/forum/portal
Which archive I must edit to configure ??
Thanks for help and sorry my horrible English
ok Limun
See - www.88id.com.br/forum/portal
did you emptyed cache affter ?
yes limun clear all cache forum and template
What's wrong with it? I see in http://www.88id.com.br/forum/portal.php that it's ok..
jpavlySend private message
jpavly wrote: [View Post]
now its perfect    maybe his server is slow
so this is solved
Hi, try to do the same but have some trouble
h**p://geesee.de/bock3/
The design is wrong. What can be wrong?
What I did so far:
- fresh phpbb installation
- install style Black Perl
- install phpbb3portal 1.2.2 (copy all files in the structure, modify , install)
- just copied the styles from prosilver into black perl dir
- copy your 3 files from post above
- looks good with prosilver
- but look what happend to portal layout
I am a beginner with all this phpbb here and would be very happy for support.
It is almost finished ... just this peace to do.
Thanks and kind regards Sascha
GeeSeeSend private message
GeeSee wrote: [View Post]
http://geesee.de/bock3/
What I did so far:
you didnt added codes in .css and in all blocks of black pearl...
i will show you ...or post files for you soon
EDIT
ok , first backup your stylesheet.css  it is in your stylesblack_pearltheme
thank download this mine attachment and extract it ...
affter extraction upload my stylesheet.css in your stylesblack_pearltheme
let me know if helped
stylesheet.rar
Description: stylesheet.css for black pearl portal
Filename: stylesheet.rar
Filesize: 3.35 KB
Downloaded: 214 Time(s)
updated with your file but still the same result
did clear the cache
I am not sure regarding the right installation of the of the theme.
Copied it from prosilver to /styles/black_pearl/template/portal/
Many thanks for help     need it
did clear the cache
download this attachment and extract it ...
try upload this folder in your stylesblack_pearltemplateportal
than again clear the cache
block.rar
Description: blocks
Filename: block.rar
Filesize: 18.31 KB
Downloaded: 198 Time(s)
works !
thanks a million
This is excellent work. The reason I won't use phpbb 3.0 is because there's no portal body.
If this would be made into a complete mod package, then I might fool around more with phpbb 3.0.
Although, since MG is always a few steps ahead of phpbb by offering his great IP CMS, I will continue using IP!
My main IP 1.3 site
My IP 1.3 styles test site
gearheadSend private messageVisit poster's website
