Post Question, Regarding Thanks Option
I was just wondering, could there be "Thanks" option for every post. And not just for topic.
Because, someone could start topic in searching for help about something. And if user who replies, gives good answer and solution. That user deserve "Thanks". But there is no way to Thank that user for good reply.
Also would be nice, to see how many "Thanks" user collected.
I didn't found that feature  among many IP features
Could someone please help me and point me the way??
strujaSend private message
Post Re: Question, Regarding Thanks Option
Since I didn't find what was I looking for in IP. Now I'm trying to install phpbb2 Thank Post by User v0.3.2 http://www.phpbb.com/community/viewtopic.php?f=16&t=441758
I've tried few times, but no success
So can someone take a quick look at the installation file, and give some pointers how to properly install it to IP
Hi
Which part are you stuck on...?
Well I can't get to show me "thanks" image in post. So problem might be in viewtopic_body.tpl
What template are you using?
ScottSend private message
Scott wrote: [View Post]
My template is milky way.
I done it. Not fully, but "thanks" image is shown, and users can thank.
There are few more features which aren't working, but I'll fix them tomorrow.
And if someone is interested in this mod I'll modify the installation file and post it.
So, just say if someone needs this mod
It doesn't seem to work properly on this site either.   I have a version that shows the users number of thanks he received in the viewtopic profile area.
Mod I'm trying to install also shows number of thanks in posts, and how many times thank have been given. And shows user who thanked under post.
But I'm having some problem with that showing users in viewtopic
This line of code should display users who thanked. Right?
<!-- BEGIN thanks -->
                <td colspan="2" class="{postrow.ROW_CLASS}" width="100%" valign="bottom"><table cellspacing="0" cellpadding="0" border="0" height="18">
                                <td valign="middle"><span class="gen">{postrow.thanks.L_THANKS_TEXT}: {postrow.thanks.THANKS_USERS}</span></td>
                </table></td>
        <!-- END thanks -->
It's not working for me. Only ":" apears, {postrow.thanks.L_THANKS_TEXT} and {postrow.thanks.THANKS_USERS} are empty.
Does anyone knows why??
Almost everything is working like it should. Except one thing in admin_forums.php
In instalation says:
$template->assign_block_vars('catrow.forumrow',
#-----[ BEFORE, ADD ]---------------------------------
                                $thanks_enabled = 'Yes';
                                $thanks_disabled = '<b>No</b>';
                                if ($forum_rows[$j]['thanks_enabled'] == 1) {
                                   $thanks_enabled = '<b>Yes</b>';
                                   $thanks_disabled = 'No';
So this piece should go somewhere in here
I understood  this piece of code like, checking is or is not thank enabled in this forum.
Also I believe that this code should be modified, that "$forum_rows[$j]" doesn't look right to me.
Any idea how to solve this, I would really appreciate
