Application Integration -- Help Would Be Appreciated.
Could someone please help me,
I have downloaded and installed an application called PHPCheckz, stand alone it works fine after a bit of tweaking with the install file, ie removing the HTTP_VARS_POST and replacing it with POST statements and moving the db.php file into the same folder as the install.php file initially and then moving it back after installation.
What i have tried to do is bridge it but with no luck.
Can someone help me use this app in my website - www.scotbird.co.uk on a seperate page and only if the user is logged in.
I currently have the phpcheckz folder within my forum folder.
Re: Application Integration -- Help Would Be Appreciated.
Right Guys,
I have scrubbed the PHPCheckz system, after playing with it stand alone it is not for me.
I think i can write what i am after, but i need help in the following
Login
I only want a user to access a page if logged in, if not i want him directed to the Login Page, how do i do that with ICY P, it was easy enough in Phpbb3 as i spent time studying it, but i am new to the IP infrastructure.
Once i have written the Database controls for my PHP app, no doubt i will be back to ask for more help.
Not had a chance to try this yet,
I have downloaded my site to local PC, set up wampserver correctly, type website in and it appears in localhost, the problem i have is:-
When ever i click on a page within local host eg click on forum link just below header and it diverts to the real website and not local host, how can i stop this so i can test my site locally ?
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation; either version 2 of the License, or
* (at your option) any later version.
* READ THIS! Wherever you see TEMPLATE or Template or template, replace with whatever you
* want to call your new page.
/***** If you create VARS (Custom) that do not already exist in Icy Phoenix, then you will also need to create the file "variables.php" for variable-transition to the .tpl file(s). So you will need to uncomment the line below.
include($phpbb_root_path . 'tickvariables.'.$phpEx);
// standard session management
$userdata = session_pagestart($user_ip, PAGE_TICKINDEX);
The time now is Mon 22 Dec, 2025 18:16 • All times are UTC + 1 Hour
