Post The Mods For !!!
i in this forum i see this:
helpsh6
can you tell the mods used for make this?
My New php is the IcyPhoenix
Kravianos PT
nickjack - View user's profileSend private messageVisit poster's website
Post Re: The Mods For !!!
they are no public MG templates at same time
*VOLVO CLUB*
difus - View user's profileSend private messageVisit poster's websiteView user's personal gallery
difus wrote: [View Post]
but i need this mods for me....por help my friends
and for this tu
See the attachment
can you help me?
Filesize: 2.18 KB
Viewed: 2349 Time(s)
Kravianos PT
You need this for translation, is that correct nickjack?
This is actually a standard template feature, not a mod. Its the in file viewforum_body.tpl - the table listing at the bottom of the file. The language file used is lang_main.php, e.g. $lang['New_posts_announcement'] = 'New posts [ Announcement ]';
I have no idea about unread posts - "permanently read" though, that seems to be arsed from nowhere! You would expect $lang['ar_posts'] somewhere... but its not even in lang_main_upi2db!
moreteavicar - View user's profileSend private messageView user's personal gallery
I go to try to better explain with the aid of the celebrity google.
I go to need to know which mod or the alterations that I must make in templates (subsilver" to appear as in this image "image1" (rank marked with reply of the member “me”)
in my php2021 i have the template subsilver but it does not appear this image
I also have template ca_aphrodite and this image already appears
Can you help me with the alterations that I must make in template to subsilver so that the image appears
How much the translation for Portuguese this almost in the end, this to delay more due to bad weather in Portugal and to have very work here, but I am to make in the free times.
And thanks for your reply.
Description: image 1
Filesize: 1.07 KB
Viewed: 2339 Time(s)
Kravianos PT
Ok, the quickest root is to go templates/ca_aphrodite/images/colourscheme - and just copy these images to subsilver, changing filenames to match existing ones in subsilver. However, some of these images depends on mods, e.g. the categories heirarchy mod, and uread posts mod, etc, which if you wanted to have them, then you would just switch from phpbb to phpBBXS. It takes over 3hrs just to install the categories heirarchy mod!
where i find this mod   uread posts mod?
Kravianos PT
http://forum.bigrib.de/phpBB2/index.php
Its all in German though!
If you just want the images, then they're in the same image directory as everythings else (depending on colour scheme)...
I have to correct you...
It's not the UPI2DB mod which allow this.
nickjack is just asking what modifications he needs to identify own posts !
In XS this is obtained with a combination of mods... Category Hierarchy and some custom modifications I did...
It's not really easy to explain what I did... because I've integrated it in UPI2DB in Recents and some other pages... but I may try when I have some free time...
In the meantime... if you want this feature, please install XS!
i server is down....
is a free server...
i have instaled xs
but i need help my friends
Kravianos PT
