Post Question About News Ticker..
Excuse me for my bad english and my question. I make a question to which you have already answered, but they are not successful to find.
Can i carry "news ticker" on portal page ? and can i carry the "shoutbox" on forum page ? What i edit ?
Thanks in advance.
Giuliano
gamelan - View user's profileSend private message
Post Re: Question About News Ticker..
You should be able to add an XS news ticker to a portal page by adding a new block with the block file xs_news (ACP>>(IM)PORTAL>>Add BLOCKS). Then in ACP>>XS News Configuration, set display news ticker to yes.
On my last attempted use of this, it didn't work properly! But that was some time back (XS 047), so maybe ok now. If it still doesn't work, try this http://www.phpBBXS.eu/viewtopic.php?t=84
moreteavicar - View user's profileSend private messageView user's personal gallery
Thanks for the answer but i've tried but don't work. The news ticker with bbc or other don't work in portal page, only in forum page.
Thank a lot for the answer.
I've fixed this in my dev package...
I don't know if these files will work with 058a, but I attach them here, so you can try them.
Please let me know it they works.
xs_news.zip
Description: New index.php and xs_news block
Filename: xs_news.zip
Filesize: 3.28 KB
Downloaded: 120 Time(s)
GREAT WORK ! Now all ok ! I've made just a little change in "forum.php" for no display news ticker, this one;
// Should the news banner be shown?
//if( $xs_news_config['xs_show_news'] && (!empty($template->xs_version)) )
//    include($phpbb_root_path . 'includes/xs_news.php');
//    $template->assign_block_vars('switch_show_news', array() );
// Generate the page
and now i've all ok !
Just a little question (if is possible) can i put shoutbox at the top of forum page ? (now is at the end).
Many many thanks for the real help
and sorry for my bad bad english (i'm italian)
Excellent MG - it was bugging me in the past, but as I made myself an i frame rss feed reader, and then Gary made one as well, I ignored the XS one completely!
@gamelan Yes, you can put the shoutbox anywhere you want! If you go to templates/ca_aphrodite/index_body.tpl
look for:
<!-- BEGIN switch_show_shoutbox -->
<table width="100%" cellspacing="0" border="0" align="center" cellpadding="0" class="forumline">
        <td align="center" nowrap="nowrap" class="catHead"><span class="cattitle"><a href="{U_SHOUTBOX_MAX}">{L_SHOUTBOX}</a></span></td>
        <td>
        <iframe src="{U_SHOUTBOX}" scrolling="NO" width="100%" height="190" frameborder="0" marginheight="0" marginwidth="0" allowtransparency="true"></iframe>
        </td>
</table>
<!-- END switch_show_shoutbox -->
To put it above the forum, move the above section to just before
{BOARD_INDEX}
Note, it should be after
{CALENDAR_BOX}
  Many thanks to all....... now i have what i want !
You are great.
Many many many thanks !
Niente... molto ben venuto
Now...
I have discovered that the xsnews block tpl (templates/ca_aphrodite/blocks/xs_news_block.tpl) has some missing tags, which can lead to display problems if using internet explorer - for e.g. the news source/from text formatting (e.g. I have my own theme and the text is supposed to be white on dark blue, but with mising tags, the text is blue on dark blue!).
Here is the correct version:
Thanks!
