Post SOLVED : Question About Logos
hi everybody!!
my question is witch file of the template is calling up the sitelogo_small.png
i´ve been searching it in css but didn´t find the line. could be as well that i need some glases.
been thinking about if changing the line it might be posible to put an gif there instead of png
could somebody please help me
Post Re: Question About Logos
spydie wrote: [View Post]
hi everybody!!
for fk_nuke or for icyphoenix ., ? because is different.
i´ve been thinking about FK_nuke themes
try to find this in templatesfk_themesoverall_header.tpl
<a href="{U_PORTAL}" title="{L_HOME}"><img src="{FULL_SITE_PATH}{SITELOGO}" alt="{L_HOME}" title="{L_HOME}"/></a></div>
Limun wrote: [View Post]
the way this look´s it doesn´t matter if sitelogo is png or gif
it´s not specified at all.
but it doesn´t work if you just change sitelogo ( i mean delete sitelogo_small.png and put sitelogo_small.gif)
that must be specified somewhere.
ahaa
than open your templatesfk_themesfk_themes.cfg
and u can change it in this line
Post SOLVED: Question About Logos
ok sorted
thanks limun
great job
I´ll call this question solved
