Post SOLVED: Problems With Download Config
hi buddy´s
got problems again. this time it is the download system. theres no way i´ve get adv-dl configured and running.
could all my problems be comming from server? i´ve seen that PHP secure mod is disabled.
help please. does somebody know how to turn that on with PHPmyadmin?
i´m sorry all the time is me with problems. that happens with newbies.
 ip_sys_check
Post Re: Problems With Download Config
I think you will have to ask your hosting service for it.
ok i´ll try that then
thank´s a lot anyway
BTW, FYI, the ctracker status image do not report any useful info.
I suggest you to try to get some little more info trought a phpinfo() fuction.
PS: You are always welcome.
Post Re: SOLVED: Problems With Download Config
fixed the problem .
the thing is that i´ve been to stupid to see the difference between /yourfile and yourfile/
logical that ip could not find the file
