If anyone is interested in translating this mod to their own language for me, it would be much appreciated.
Thanks for any help, and don't forget to add your Name and Links etc to the top.
Spoiler: [ Hide ]
Code: [Download] [Show]
<?php
* @package Icy Phoenix Modifications
* @File $Id: lang_extend_medal_mod.php
* @copyright (c) 2008 Y.C. LIN
* @email: ycl6@users.sourceforge.net
* @license: h**p://opensource.org/licenses/GPL-license.php GNU Public License
* @Extra credits for this file
* Modified for Icy Phoenix by Lopalong - 01-Jan-2009
if (!defined('IN_ICYPHOENIX'))
exit;
if (empty($lang) || !is_array($lang))
$lang = array();
$lang = array_merge($lang, array(
// START Medal MOD
// START Medal Admin
'Medals' => 'Medal Admin',
'Manage' => 'Management',
'Medal_Config' => 'Medal Configuration',
'Medal_Config_explain' => 'Customise the medal options.',
'Medal_setting' => 'Medal Settings for Viewtopic',
'Allow_medal' => 'Allow Medal Display',
'Medal_rand' => 'Allow Random Medal',
'Medal_rand_explain' => 'Display medals in random order.',
'Medal_display' => 'Medal Rows x Columns',
'Medal_display_explain' => 'E.g. 1 row and 1 column displays 1 medal, and 1 row, 2 columns displays 2 medals.',
'Medal_size' => 'Medal Height x Width (in pixels)',
'Medal_size_explain' => 'If left blank, medals will be displayed in their original size',
'Click_return_medalcfg' => 'Click %sHere%s to return to Medal Configuration.',
'Medal_admin' => 'Medal Administration',
'Medal_admin_explain' => 'Delete, create or edit medals and moderators.',
'Updated_medal' => 'Medal updated successfully',
'Updated_medal_category' => 'Medal category updated successfully',
'Added_new_medal' => 'New medal created successfully',
'Added_new_category' => 'New medal category created successfully',
'Deleted_medal' => 'Medal deleted successfully',
'Deleted_medal_category' => 'Medal category deleted successfully',
'New_medal' => 'Create new medal',
'medal_name' => 'Medal Name',
'medal_description' => 'Description',
'medal_image' => 'Image',
'medal_image_explain' => 'Define an image associated with the medal<br />(Relative to Icy Phoenix root path)',
'No_medal_name' => 'You must specify a name for this medal',
'No_medal_description' => 'You must add a description for this medal',
'No_medal_image' => 'You must add an image for this medal',
'Must_select_medal' => 'You must specify a medal',
'Click_return_medaladmin' => 'Click %sHere%s to return to Medal Administration.',
'Medal_mod' => 'Moderator',
'Medal_mod_admin' => 'Medal Moderator Administration',
'Medal_mod_admin_explain' => 'Appoint or remove medal moderators.',
'Medal_mod_username' => 'Appoint Moderator',
'Medal_unmod_username' => 'Remove Moderator',
'Medal_unmod_username_explain' => 'You can highlight multiple users with your mouse and keyboard functions.',
'No_medal_mod' => 'No Medal Moderator',
'No_medal_in_cat' => 'No medal in this category',
'Must_delete_medal' => 'You must delete all medals before you can delete this category',
'Category_deletion' => 'Delete Medal Category',
'Category_deletion_explain' => 'Delete a category and decide where you want to put all the medals it contained.',
'Move_medals' => 'Move medals to',
'Category_name' => 'Category Name',
'Medal_mod_update_sucessful' => 'Medal Moderator has been updated successfully',
'Click_return_medal_mod_admin' => 'Click %sHere%s to return to Medal Moderator Administration.',
// END Medal Admin
// START Medal Front End
'Medal_Control_Panel' => 'Medal Control Panel',
'Medals' => 'Medals',
'View_More' => 'View more...',
'Medal_amount' => 'Amount: ',
'Medal_Information' => 'Medal Information',
'Medal_name' => 'Medal Name',
'Medal_description' => 'Description',
'Medal_image' => 'Image',
'Medal_details' => 'Award Details',
'Medal_reason' => 'Reason',
'Medal_reason_explain' => 'Though not required, you can enter the reason for this award.',
'Medal_no_reason' => '<em>No Reason was given</em>',
'Medal_time' => 'Awarded On',
'Medal_moderator' => 'Moderator',
'No_medal_mod' => 'No Moderator',
'Medal_userlist' => 'User Lists',
'Medal_Members' => 'Awarded To',
'Medal_Members_explain' => 'Click on a username to edit award reason(s)',
'No_medal_members' => 'No member has this medal',
'No_medals_exist' => 'No Medals Exist',
'Medal_not_exist' => 'That medal does not exist',
'No_username_specified' => 'No username specified',
'No_medal_id_specified' => 'No Medals specified',
'Medal_user_username' => 'Award Medal',
'Medal_unmedal_username' => 'Remove Medal',
'Medal_unmedal_username_explain' => 'You can highlight multiple users with your mouse and keyboard functions.',
'Medal_added' => 'You have been awarded this medal.',
'Medal_update_sucessful' => 'User and Medal information has been updated',
'Could_not_anonymous_user' => 'You cannot give Anonymous a medal.',
'Not_medal_moderator' => 'You are not a moderator of this medal',
'Link_to_cp' => 'Medal CP',
'Click_return_medal' => 'Click %sHere%s to return to medal information',
'No_medal' => 'No Medal Available',
// END Medal Front End
// END Medal Mod
Edited by Guest, Mon 29 Dec, 2008 10:58: Seems I forgot to "Spoil" it and set a bad example. :(
Edited by Guest, Fri 02 Jan, 2009 11:53: Changed the File Headers
$lang = array();
// START Medal MOD
'Added_new_category' => 'Nova kategorija medalja uspiješno stvorena',
'Added_new_category' => '',
'Added_new_medal' => 'Nova medalja uspiješno stvorena',
'Added_new_medal' => '',
'Allow_medal' => 'Dozvoli prikaz medalja',
'Allow_medal' => '',
'Category_deletion' => 'Obriši kategoriju medalja',
'Category_deletion' => '',
'Category_deletion_explain' => 'Obriši kategoriju i odlući gdje ćes postavit komentar medalje.',
'Category_deletion_explain' => '',
'Category_name' => 'Ime kategorije',
'Category_name' => '',
'Click_return_medal_mod_admin' => 'Klikni %sOvdje%s za povratak na moderator kontrolu medalja.',
'Click_return_medal_mod_admin' => ' %sOvdje%s ',
'Click_return_medaladmin' => 'Klikni %sOvdje%s za povratak na Administraciju medalja.',
'Click_return_medaladmin' => ' %sOvdje%s ',
'Click_return_medalcfg' => 'Klikni %sOvdje%s za povratak na konfiguraciju madalja.',
'Click_return_medalcfg' => ' %sOvdje%s ',
'Deleted_medal' => 'Medalja uspiješno obrisana',
'Deleted_medal' => '',
'Deleted_medal_category' => 'Kategorija medalja uspiješno obrisana',
'Deleted_medal_category' => '',
'Manage' => 'Menađment',
'Manage' => '',
'Medal_Config' => 'Konfiguracija Medalja',
'Medal_Config' => '',
'Medal_Config_explain' => '',
'Medal_admin' => 'Administracija medalja',
'Medal_admin' => '',
'Medal_admin_explain' => 'Obriši, stvori ili modificiraj moderatore i medalje.',
'Medal_admin_explain' => '',
'Medal_display' => 'Medalje Stupci x Redovi',
'Medal_display' => '',
'Medal_display_explain' => 'Npr. 1 stupac i 1 red prikazuje 1 medalju, i 1 stupac, 2 reda prikazuju 2 medalje.',
'Medal_display_explain' => '',
'Medal_mod' => '',
'Medal_mod_admin' => 'Administracija moderatora medalja',
'Medal_mod_admin' => '',
'Medal_mod_admin_explain' => 'Dodaj ili ukloni moderatora medalja.',
'Medal_mod_admin_explain' => '',
'Medal_mod_update_sucessful' => 'Moderator medalja uspiešno ažuriran',
'Medal_mod_update_sucessful' => '',
'Medal_mod_username' => 'Dodaj Moderatora',
'Medal_mod_username' => '',
'Medal_rand' => 'Dozvoli slučajan izbor',
'Medal_rand' => '',
'Medal_rand_explain' => 'Prikaži medalje po slučajnom izboru.',
'Medal_rand_explain' => '',
'Medal_setting' => 'Opcije medalja za Viewtopic',
'Medal_setting' => '',
'Medal_size' => 'Medalje Visina x Širina (u pikselima)',
'Medal_size' => '',
'Medal_size_explain' => 'Ako je lijevo prazno, medalje će biti prikazane u originalnoj veličini',
'Medal_size_explain' => '',
'Medal_unmod_username' => 'Makni Moderatora',
'Medal_unmod_username' => '',
'Medal_unmod_username_explain' => 'Možeš naglasit više korisnika sa mišem i tipkovnicom.',
'Medal_unmod_username_explain' => '',
'Medals' => 'Administrator Medalja',
'Medals' => '',
'Move_medals' => 'Premjesti medalje u',
'Move_medals' => '',
'Must_delete_medal' => 'Moraš obrisati medalju prije nego možeš obrisati kategoriju',
'Must_delete_medal' => '',
'Must_select_medal' => 'Moraš odrediti medalju',
'Must_select_medal' => '',
'New_medal' => 'Stvori novu medalju',
'New_medal' => '',
'No_medal_description' => 'Moraš unjeti opis za ovu medalju',
'No_medal_description' => '',
'No_medal_image' => 'Moraš dodati sliku za ovu medalju',
'No_medal_image' => '',
'No_medal_in_cat' => 'Nema medalja u kategoriji',
'No_medal_in_cat' => '',
'No_medal_mod' => 'Nema Moderatora medalja',
'No_medal_mod' => '',
'No_medal_name' => 'Moraš izabrati ime za medalju',
'No_medal_name' => '',
'Updated_medal' => 'Medalja uspiješno ažurirana',
'Updated_medal' => '',
'Updated_medal_category' => 'Kategorija Medalja uspiješno ažurirana',
'Updated_medal_category' => '',
'medal_description' => 'Opis',
'medal_description' => '',
'medal_image' => 'Slika',
'medal_image' => '',
'medal_image_explain' => 'Odaberi sliku povezanu s medaljon<br />(Putanja po Icy Phoenix root path)',
'medal_image_explain' => '',
'medal_name' => 'Ime medalje',
'medal_name' => '',
// END Medal Admin
'Click_return_medal' => 'Klikni %sOvdje%s za povratak ne info o medalji',
'Click_return_medal' => ' %sOvdje%s ',
'Could_not_anonymous_user' => 'Ne možete dati Anonimcu medalju.',
'Could_not_anonymous_user' => '',
'Link_to_cp' => 'CP Medalja',
'Link_to_cp' => '',
'Medal_Control_Panel' => 'Kontorlni Panel Medalje',
'Medal_Control_Panel' => '',
'Medal_Information' => 'Info Medalje',
'Medal_Information' => '',
'Medal_Members' => 'Nagrada za',
'Medal_Members' => '',
'Medal_Members_explain' => 'Klikni na korisnika za uredit razlog nagrade',
'Medal_Members_explain' => '',
'Medal_added' => 'Nagrađeni ste s ovom medaljom.',
'Medal_added' => '',
'Medal_amount' => 'Količina: ',
'Medal_amount' => '',
'Medal_description' => 'Opis',
'Medal_description' => '',
'Medal_details' => 'Detalji nagrade',
'Medal_details' => '',
'Medal_image' => 'Slika',
'Medal_image' => '',
'Medal_moderator' => '',
'Medal_name' => 'Ime Medalje',
'Medal_name' => '',
'Medal_no_reason' => '<em>Razlog nije dodan</em>',
'Medal_no_reason' => '<em></em>',
'Medal_not_exist' => 'Ta medalja ne postoji',
'Medal_not_exist' => '',
'Medal_reason' => 'Razlog',
'Medal_reason' => '',
'Medal_reason_explain' => 'Iako nije potrebno, možete unijeti razlog za nagradu.',
'Medal_reason_explain' => '',
'Medal_time' => 'Nagrađeno',
'Medal_time' => '',
'Medal_unmedal_username' => 'Makni Medalju',
'Medal_unmedal_username' => '',
'Medal_unmedal_username_explain' => 'Možeš naglasit više korisnika sa mišem i tipkovnicom.',
'Medal_unmedal_username_explain' => '',
'Medal_update_sucessful' => 'Informacija o korisniku i medalji uspiješno ažurirana',
'Medal_update_sucessful' => '',
'Medal_user_username' => 'Nagrada Medalja',
'Medal_user_username' => '',
'Medal_userlist' => 'Lista korisnika',
'Medal_userlist' => '',
'Medals' => 'Medalje',
'Medals' => '',
'No_medal' => 'Nema dostupne medalje',
'No_medal' => '',
'No_medal_id_specified' => 'Nisu odabrane medalje',
'No_medal_id_specified' => '',
'No_medal_members' => 'Nema korisnika s ovom medaljom',
'No_medal_members' => '',
'No_medal_mod' => 'Nema Moderatora',
'No_medals_exist' => 'Nema niti jedne medalje',
'No_medals_exist' => '',
'No_username_specified' => 'Nije odabrano nijedno ime',
'No_username_specified' => '',
'Not_medal_moderator' => 'Nisi Moderator za ovu medalju',
'Not_medal_moderator' => '',
'View_More' => 'Vidi još...',
'View_More' => '...',
// END Medal Mod
Edited by Guest, Mon 29 Dec, 2008 11:00: I forgot to spoil the original post. :(
Thank you Limun, and I thought that may have been the problem.
Anyway, maybe this request was a bit premature for a mod that is for the "Next Release" of IP, when there are still so many changes being made to the core files.
The lang translation you did will be fine, and thanks for that - But meantime I think I'll lock this topic until after the next "Public Release" of IP.
<?php
* @version $Id: lang_extend_medal_mod.php 1st January 09 $
* @license http://opensource.org/licenses/GPL-license.php GNU Public License
// ------------[ Contributors ]-------------------
// Translated to "Spanish" by: "ThE KuKa"
// Website: http://www.icyphoenix.es
exit;
$lang = array();
// START Medal MOD
'Added_new_category' => 'Nueva categoría de medalla creada correctamente',
'Added_new_medal' => 'Nueva medalla creada correctamente',
'Allow_medal' => 'Permitir mostrar medalla',
'Category_deletion' => 'Borrar categoría de medalla',
'Category_deletion_explain' => 'Borrar una categoría y decidir donde quieres poner todas las medallas que contenía.',
'Category_name' => 'Nombre de la categoría',
'Click_return_medal_mod_admin' => 'Clic %sAquí%s para volver a la Administración de Moderador de Medalla.',
'Click_return_medaladmin' => 'Clic %sAquí%s para volver a la Administración de Medalla.',
'Click_return_medalcfg' => 'Clic %sAquí%s para volver a la Configuración de Medalla.',
'Deleted_medal' => 'Medalla borrada correctamente',
'Deleted_medal_category' => 'Categoría de medalla borrada correctamente',
'Manage' => 'Administrar',
'Medal_Config' => 'Configuración de Medalla',
'Medal_Config_explain' => 'Personalizar las opciones de medalla.',
'Medal_admin' => 'Administración de Medalla',
'Medal_admin_explain' => 'Borrar, crear o editar medallas y moderadores.',
'Medal_display' => 'Filas x Columnas de medalla',
'Medal_display_explain' => 'Por ejemplo, 1 fila y 1 columna muestra 1 medalla, y 1 fila, 2 columnas muestran 2 medallas.',
'Medal_mod' => 'Moderador',
'Medal_mod_admin' => 'Administración de Moderador de Medalla',
'Medal_mod_admin_explain' => 'Nombrar o quitar moderadores de medalla.',
'Medal_mod_update_sucessful' => 'Moderador de medalla ha sido actualizado correctamente',
'Medal_mod_username' => 'Nombrar Moderador',
'Medal_rand' => 'Permitir medalla aleatoria',
'Medal_rand_explain' => 'Mostrar medallas en orden aleatorio.',
'Medal_setting' => 'Ajustes de medalla para Viendo un tema (Viewtopic)',
'Medal_size' => 'Altura x Anchura de medalla (en píxeles)',
'Medal_size_explain' => 'Si lo deja en blanco, las medallas se mostrarán en su tamaño original',
'Medal_unmod_username' => 'Quitar Moderador',
'Medal_unmod_username_explain' => 'Puede destacar varios usuarios con las funciones del ratón y/o el teclado.',
'Medals' => 'Administración de Medalla',
'Move_medals' => 'Mover medallas a',
'Must_delete_medal' => 'Usted debe borrar todas las medallas, antes de borrar esta categoría',
'Must_select_medal' => 'Usted debe especificar una medalla',
'New_medal' => 'Crear nueva medalla',
'No_medal_description' => 'Usted debe agregar una descripción para esta medalla',
'No_medal_image' => 'Usted debe añadir una imagen para esta medalla',
'No_medal_in_cat' => 'No hay medalla en esta categoría',
'No_medal_mod' => 'No hay Moderador de medalla',
'No_medal_name' => 'Usted debe especificar un nombre para esta medalla',
'Updated_medal' => 'Medalla actualizada correctamente',
'Updated_medal_category' => 'Categoría de medalla actualizada correctamente',
'medal_description' => 'Descripción',
'medal_image' => 'Imagen',
'medal_image_explain' => 'Definir una imagen asociada a la medalla<br />(Relativa a la ruta raíz de Icy Phoenix)',
'medal_name' => 'Nombre de medalla',
// END Medal Admin
'Click_return_medal' => 'Clic %sAquí%s para volver a la Información de Medalla',
'Could_not_anonymous_user' => 'Usted no puede dar una medalla a Invitados.',
'Link_to_cp' => 'PC Medalla',
'Medal_Control_Panel' => 'Panel de COntrol de Medalla',
'Medal_Information' => 'Información de Medalla',
'Medal_Members' => 'Concedida a',
'Medal_Members_explain' => 'Clic en un nombre de usuario para editar la razón (o razones) del premio',
'Medal_added' => 'Usted ha sido premiado con esta medalla.',
'Medal_amount' => 'Cantidad: ',
'Medal_description' => 'Descripción',
'Medal_details' => 'Detalles del Premio',
'Medal_image' => 'Imagen',
'Medal_moderator' => 'Moderador',
'Medal_name' => 'Nombre de la medalla',
'Medal_no_reason' => '<em>No se le dio la razón, o explicación del porque este premio.</em>',
'Medal_not_exist' => 'Esta medalla no existe',
'Medal_reason' => 'Razón',
'Medal_reason_explain' => 'Aunque no es necesario, puede introducir la razón, o motivo de este premio.',
'Medal_time' => 'Concedida el',
'Medal_unmedal_username' => 'Quitar medalla',
'Medal_unmedal_username_explain' => 'Puede destacar varios usuarios con las funciones del ratón y/o el teclado.',
'Medal_update_sucessful' => 'Información de usuario y medalla actualizada',
'Medal_user_username' => 'Medalla de premio',
'Medal_userlist' => 'Lista de usuarios',
'Medals' => 'Medallas',
'No_medal' => 'No hay medalla disponible',
'No_medal_id_specified' => 'No se especificarón medallas',
'No_medal_members' => 'Ningún usuario tiene esta medalla',
'No_medal_mod' => 'Sin Moderador',
'No_medals_exist' => 'No existen medallas',
'No_username_specified' => 'No se especifico nombre de usuario',
'Not_medal_moderator' => 'Usted no es Moderador de esta medalla',
'View_More' => 'Ver más...',
* @email:
* @license: http://opensource.org/licenses/GPL-license.php GNU Public License
* Translated to "Dutch" by: "Harimau" - 05-April-2009
exit;
$lang = array();
// START Medal MOD
'Medals' => 'Medaille Admin',
'Medal_Config' => 'Medaille Configuratie',
'Medal_Config_explain' => 'Persoonlijk maken van de Medaille opties.',
'Medal_setting' => 'Medaille Instellingen voor Viewtopic',
'Allow_medal' => 'Sta Beeldvenster Medaille Toe',
'Medal_rand' => 'Sta willekeurige Medailles toe',
'Medal_rand_explain' => 'Toon medailles in willekeurige volgorde.',
'Medal_display' => 'Medaille Rijen x Kolommen',
'Medal_display_explain' => 'Voorb. 1 rij en 1 kolom toont 1 medaille, en 1 rij, 2 kolommen tonen 2 medailles.',
'Medal_size' => 'Medaille Hoogte x Breedte (in pixels)',
'Medal_size_explain' => 'Als het blanco blijft, zullen medailles op originele wijze getoond worden',
'Click_return_medalcfg' => 'Klik %sHier%s om terug te keren naar Medaille Configuratie.',
'Medal_admin' => 'Medaille Administratie',
'Medal_admin_explain' => 'Verwijderen, maken of bewerk medailles en moderators.',
'Updated_medal' => 'Medailles succesvol geupdate',
'Updated_medal_category' => 'Medaille categorie succesvol geupdate',
'Added_new_medal' => 'Nieuwe Medaille succesvol gecreeerd',
'Added_new_category' => 'Nieuwe medaille categorie succesvol gecreeerd',
'Deleted_medal' => 'Medaille succesvol verwijderd',
'Deleted_medal_category' => 'Medaille categorie succesvol verwijderd',
'New_medal' => 'Maak een nieuwe medaille',
'medal_name' => 'Medaille Naam',
'medal_description' => 'Beschrijving',
'medal_image' => 'Afbeelding',
'medal_image_explain' => 'Specificeer een afbeelding die geassocieerd is met de medaille<br />(Gerelateerd aan Icy Phoenix root path)',
'No_medal_name' => 'Je moet een naam ingeven voor deze medaille',
'No_medal_description' => 'Je moet een beschrijving geven voor deze medaille',
'No_medal_image' => 'Je moet een afbeelding toevoegen voor deze medaille',
'Must_select_medal' => 'Je moet een medaille specificeren',
'Click_return_medaladmin' => 'Klik %sHier%s om terug te keren in het Medaille Administratie.',
'Medal_mod_admin' => 'Medaille Moderator Administratie',
'Medal_mod_admin_explain' => 'Benoem of verwijder medaille moderators.',
'Medal_mod_username' => 'Benoem Moderator',
'Medal_unmod_username' => 'Verwijder Moderator',
'Medal_unmod_username_explain' => 'Je kan meerdere gebruikers selecteren met de muis en toetsenbord functies.',
'No_medal_mod' => 'Geen Medaille Moderator',
'No_medal_in_cat' => 'Geen medaille in deze categorie',
'Must_delete_medal' => 'Je moet eerst alle medailles verwijderen voordat je de categorie kan verwijderen',
'Category_deletion' => 'Verwijder Medaille Categorie',
'Category_deletion_explain' => 'Verwijder een categorie en beslis of je alle medailles gebundeld wilt bewaren.',
'Move_medals' => 'Verplaats de medailles naar',
'Category_name' => 'Categorie Naam',
'Medal_mod_update_sucessful' => 'Medaille Moderator is succesvol geupdate',
'Click_return_medal_mod_admin' => 'Klik %sHier%s om terug te keren naar de Medaille Moderator Administratie.',
// END Medal Admin
'Medal_Control_Panel' => 'Medaille Controle Paneel',
'Medals' => 'Medailles',
'View_More' => 'Bekijk meer...',
'Medal_amount' => 'Hoeveelheid: ',
'Medal_Information' => 'Medaille Informatie',
'Medal_name' => 'Medaille Naam',
'Medal_description' => 'Omschrijving',
'Medal_image' => 'Afbeelding',
'Medal_details' => 'Toegekende details',
'Medal_reason' => 'Reden',
'Medal_reason_explain' => 'Hoewel niet vereist, kun je wel een reden voor deze toekenning invoeren.',
'Medal_no_reason' => '<em>Geen reden opgegeven</em>',
'Medal_time' => 'Toegekend Op',
'No_medal_mod' => 'Geen Moderator',
'Medal_userlist' => 'Gebruikers Lijst',
'Medal_Members' => 'Toegewezen Aan',
'Medal_Members_explain' => 'Klik op de gebruikersnaam om de toekenning(en) te bewerken',
'No_medal_members' => 'Geen enkele gebruikers heeft deze medaille',
'No_medals_exist' => 'Geen Medailles Bestaan',
'Medal_not_exist' => 'Deze medaille bestaat niet',
'No_username_specified' => 'Geen gebruiker geselecteerd',
'No_medal_id_specified' => 'Geen medaille geselecteerd',
'Medal_user_username' => 'Medaille toekennen',
'Medal_unmedal_username' => 'Medaille verwijderen',
'Medal_unmedal_username_explain' => 'Je kan meerdere gebruikers selecteren met de muis en toetsenbord functies.',
'Medal_added' => 'Je hebt een medaille ontvangen.',
'Medal_update_sucessful' => 'Gebruiker en Medaille informatie is geupdate',
'Could_not_anonymous_user' => 'Je kan niet Anoniem een medaille toewijzen.',
'Not_medal_moderator' => 'Je bent geen moderator van deze medaille',
'Link_to_cp' => 'Medaille CP',
'Click_return_medal' => 'Klik %sHier%s om terug te keren naar de medaille informatie',
'No_medal' => 'Geen Medaille Beschikbaar',
// END Medal Mod
* @email:
* Translated to "Français" by: "Chillyboarder" - 07-April-2009
exit;
$lang = array();
// START Medal MOD
'Medals' => 'Médaille Admin',
'Manage' => 'Administration',
'Medal_Config' => 'Configuration de Médaille',
'Medal_Config_explain' => 'Personnalisez les options de médaille.',
'Medal_setting' => 'Cadres de Médaille pour Viewtopic',
'Allow_medal' => 'Permettez l'Étalage de Médaille',
'Medal_rand' => 'Permettez la Médaille Au hasard',
'Medal_rand_explain' => 'Médailles d'étalage dans l'ordre au hasard.',
'Medal_display' => 'Rangs de Médaille x Colonnes',
'Medal_display_explain' => 'Par ex. 1 rang et 1 colonne affichent 1 médaille et 1 rang, 2 colonnes affichent 2 médailles.',
'Medal_size' => 'La Hauteur de Médaille x la Largeur (en pixels)',
'Medal_size_explain' => 'Si quitté le blanc, les médailles seront affichées par leur grandeur originale',
'Click_return_medalcfg' => 'Pressez %sIci%s pour revenir à la Configuration de Médaille.',
'Medal_admin' => 'Administration de Médaille',
'Medal_admin_explain' => 'Effacez, créez ou révisez des médailles et des modérateurs.',
'Updated_medal' => 'Médaille actualisée avec succès',
'Updated_medal_category' => 'Catégorie de médaille actualisée avec succès',
'Added_new_medal' => 'Nouvelle médaille créée avec succès',
'Added_new_category' => 'Nouvelle catégorie de médaille créée avec succès',
'Deleted_medal' => 'Médaille effacée avec succès',
'Deleted_medal_category' => 'Catégorie de médaille effacée avec succès',
'New_medal' => 'Créez la nouvelle médaille',
'medal_name' => 'Nom de Médaille',
'medal_image_explain' => 'Définissez une image associée à la médaille <br/> (Quant au sentier de racine de Phoenix Glacial)',
'No_medal_name' => 'Vous devez spécifier un nom pour cette médaille',
'No_medal_description' => 'Vous devez ajouter une description pour cette médaille',
'No_medal_image' => 'Vous devez ajouter une image pour cette médaille',
'Must_select_medal' => 'Vous devez spécifier une médaille',
'Click_return_medaladmin' => 'Pressez %sIci%s pour revenir à l'Administration de Médaille.',
'Medal_mod' => 'Modérateur',
'Medal_mod_admin' => 'Administration de Modérateur de Médaille',
'Medal_mod_admin_explain' => 'Nommez ou enlevez des modérateurs de médaille.',
'Medal_mod_username' => 'Nommez le Modérateur',
'Medal_unmod_username' => 'Enlevez le Modérateur',
'Medal_unmod_username_explain' => 'Vous pouvez accentuer des utilisateurs multiples avec votre souris et fonctions de clavier.',
'No_medal_mod' => 'Aucun Modérateur de Médaille',
'No_medal_in_cat' => 'Aucune médaille dans cette catégorie',
'Must_delete_medal' => 'Vous devez effacer toutes les médailles avant que vous pouvez effacer cette catégorie',
'Category_deletion' => 'Effacez la Catégorie de Médaille',
'Category_deletion_explain' => 'Effacez une catégorie et décidez où vous voulez mettre toutes les médailles qu'il a contenues.',
'Move_medals' => 'Médailles de mouvement à',
'Category_name' => 'Nom de Catégorie',
'Medal_mod_update_sucessful' => 'Le Modérateur de Médaille a été actualisé avec succès',
'Click_return_medal_mod_admin' => 'Pressez %sIci%s pour revenir à l'Administration de Modérateur de Médaille.',
// END Medal Admin
'Medal_Control_Panel' => 'Pupitre de commande de Médaille',
'Medals' => 'Médailles',
'View_More' => 'Voyez plus...',
'Medal_amount' => 'Quantité: ',
'Medal_Information' => 'Informations de Médaille',
'Medal_name' => 'Nom de Médaille',
'Medal_details' => 'Détails de Prix',
'Medal_reason' => 'Raison',
'Medal_reason_explain' => 'Bien que non exigé, vous puissiez entrer dans la raison pour ce prix.',
'Medal_no_reason' => '<em>Aucune Raison n'a été apportée</em>',
'Medal_time' => 'Décerné Sur',
'Medal_moderator' => 'Modérateur',
'No_medal_mod' => 'Aucun Modérateur',
'Medal_userlist' => 'L'Utilisateur Énumère',
'Medal_Members' => 'Décerné À',
'Medal_Members_explain' => 'Cliquez sur un nom d'utilisateur pour réviser la raison(s) de prix',
'No_medal_members' => 'Aucun membre n'a cette médaille',
'No_medals_exist' => 'Aucune Médaille n'Existe',
'Medal_not_exist' => 'Cette médaille n'existe pas',
'No_username_specified' => 'Aucun nom d'utilisateur spécifié',
'No_medal_id_specified' => 'Aucune Médaille spécifiée',
'Medal_user_username' => 'Médaille de Prix',
'Medal_unmedal_username' => 'Enlevez la Médaille',
'Medal_unmedal_username_explain' => 'Vous pouvez accentuer des utilisateurs multiples avec votre souris et fonctions de clavier.',
'Medal_added' => 'On vous a décerné cette médaille.',
'Medal_update_sucessful' => 'Les informations de Médaille et d'utilisateur ont été actualisés',
'Could_not_anonymous_user' => 'Vous ne pouvez pas donner Anonyme une médaille.',
'Not_medal_moderator' => 'Vous n'êtes pas un modérateur de cette médaille',
'Link_to_cp' => 'PC de médaille',
'Click_return_medal' => 'Pressez %sIci%s pour revenir aux informations de médaille',
'No_medal' => 'Aucune Médaille Disponible',
// END Medal Mod
exit;
$lang = array();
// START Medal MOD
'Medals' => 'Medaglie',
'Manage' => 'Amministrazione',
'Medal_Config' => 'Configurazione Medaglie',
'Medal_Config_explain' => 'Da questo pannello di controllo puoi amministrare le medaglie da assegnare ai tuoi utenti.',
'Medal_setting' => 'Impostazione Medaglie per Topic',
'Allow_medal' => 'Permetti visualizzazione medaglie',
'Medal_rand' => 'Permetti medaglie casuali',
'Medal_rand_explain' => 'Visualizza medaglie in ordine casuale.',
'Medal_display' => 'Medaglie Righe X Colonne',
'Medal_display_explain' => 'Qui puoi configurare come visualizzare le medaglie Esempio: 1 riga e 1 colonna visualizza 1 medaglia. 2 righe e 2 colonne visualizza 2
medaglie.',
'Medal_size' => 'Altezza e Larghezza Medaglie (in pixels)',
'Medal_size_explain' => 'Da qui configuri come visualizzare le medaglie in altezza e in larghezza. Se lasci il campo in bianco la medaglia verrà visualizzata
nelle dimensioni originali.',
'Click_return_medalcfg' => 'Clicca %sQui%s per ritornare a Configurazione Medaglie.',
'Medal_admin' => 'Amministrazione Medaglie',
'Medal_admin_explain' => 'Da questo pannello di controllo puoi Creare, Modificare, Cancellare e Moderare le Medaglie da assegnare.',
'Updated_medal' => 'La Medaglia è stata aggiornata con successo.',
'Updated_medal_category' => 'La Categoria della Medaglia è stat aggiornata con successo.',
'Added_new_medal' => 'Una nuova Medaglia è stata creata con successo.',
'Added_new_category' => 'Una nuova categoria per le medaglie è stata creata con successo.',
'Deleted_medal' => 'La Medaglia è stata cancellata con successo.',
'Deleted_medal_category' => 'La categoria delle medaglie è stata cancellata con successo',
'New_medal' => 'Crea una nuova Medaglia',
'medal_name' => 'Nome Medaglia',
'medal_description' => 'Descrizione',
'medal_image' => 'Immagine',
'medal_image_explain' => 'Definisci un immagine associata alla medaglia.',
'No_medal_name' => 'Occorre specificare un nome per questa medaglia.',
'No_medal_description' => 'Occorre specificare una descrizione per questa medaglia.',
'No_medal_image' => 'Occorre specificare un immagine per questa medaglia.',
'Must_select_medal' => 'Occorre specificare la medaglia',
'Click_return_medaladmin' => 'Clicca %sQui%s per ritornare al pannello Amministrazione Medaglie.',
'Medal_mod' => 'Moderatore',
'Medal_mod_admin' => 'Amministrazione Moderatori Medaglie',
'Medal_mod_admin_explain' => 'Nomina o Rimuovi Moderatori per le medaglie.',
'Medal_mod_username' => 'Nomina Moderatore',
'Medal_unmod_username' => 'Rimuovi Moderatore',
'Medal_unmod_username_explain' => 'E\' possibile evidenziare più utenti con funzioni di mouse e tastiera.',
'No_medal_mod' => 'Non esistono Moderatori',
'No_medal_in_cat' => 'Non ci sono Medaglie in questa Categoria',
'Must_delete_medal' => 'Occorre cancellare tutte le medaglie presenti nella Categoria prima di Cancellare la stessa',
'Category_deletion' => 'Cancella categoria Medaglie',
'Category_deletion_explain' => 'Elimina una categoria e decidi dove vuoi mettere tutte le medaglie che essa contiene.',
'Move_medals' => 'Sposta le Medaglie a',
'Category_name' => 'Nome Categoria',
'Medal_mod_update_sucessful' => 'Il Moderatore per le Medaglie è stato aggiornato con successo.',
'Click_return_medal_mod_admin' => 'Clicca %sQui%s per ritornare al Pannello di Controllo dei Moderatori per le medaglie.',
// END Medal Admin
'Medal_Control_Panel' => 'Pannello di Controllo Medaglie',
'View_More' => 'Visualizza più Medaglie',
'Medal_amount' => 'Importo: ',
'Medal_Information' => 'Informazioni Medaglia',
'Medal_name' => 'Nome Medaglia',
'Medal_description' => 'Descrizione',
'Medal_image' => 'Immagine',
'Medal_details' => 'Dettagli',
'Medal_reason' => 'Motivo',
'Medal_reason_explain' => 'Anche se non è richiesto, inserire una motivazione per il premio.',
'Medal_no_reason' => '<em>Non è stata data una motivazione specifica per il premio</em>',
'Medal_time' => 'Premiazione Attivata',
'Medal_moderator' => 'Moderatore',
'No_medal_mod' => 'Non esiste un Moderatore',
'Medal_userlist' => 'Lista Utenti',
'Medal_Members' => 'Premiazione per',
'Medal_Members_explain' => 'Scegli il nome dell'utente per modificare la/le motivazione/i del/dei prem/i/io.',
'No_medal_members' => 'Nessun Utente ha questa Medaglia',
'No_medals_exist' => 'Non sono presenti Medaglie',
'Medal_not_exist' => 'Questa Medaglia non esiste',
'No_username_specified' => 'Non è stato specificato nessun utente',
'No_medal_id_specified' => 'Non è stata specificata nessuna Medaglia',
'Medal_user_username' => 'Premio Medaglia',
'Medal_unmedal_username' => 'Rimuovi medaglia',
'Medal_unmedal_username_explain' => 'E\' possibile evidenziare più utenti con funzioni di mouse e tastiera.',
'Medal_added' => 'Hai ottenuto questa Medaglia.',
'Medal_update_sucessful' => 'Le Informazioni dell'utente e della Medaglia sono state aggiornate con successo.',
'Could_not_anonymous_user' => 'Non si può dare una Medaglia ad un visitatore',
'Not_medal_moderator' => 'Spiacente!!! Non sei moderatore di questa Medaglia',
'Link_to_cp' => 'P C M',
'Click_return_medal' => 'Clicca %sQui%s per ritornare ad Informazioni Medaglie',
'No_medal' => 'Non ci sono Medaglie disponibili',
// END Medal Mod
The time now is Fri 20 Feb, 2026 01:32 • All times are UTC + 1 Hour
